FMS 228 114 is in!
Sounds pretty mean. It is louder and has a small lope. Hopefully, it will sound better after the tune.
During the install I only ran into two hang-ups. One, I dropped a retainer lock when changing the springs, and it just vanished. I guess that little gremlin got it, the same one who steals my socks, sockets, keys, and what not.
Then I broke a water pump bolt off in my head. I was using it with a spring compressor tool. It snapped off flush behingd the cowl so I couldnt get a drill back there to get it out. I finnaly had to use a dremel and cut a slit in the top and use a shorty flathead to get it out.
Overall it was a great experience, and I would recommend anyone who hasent done it yet, to give it a try if they get the chance. Man, I cant wait to see what this thing does at the dyno and the track. Hopefully, Ill have some numbers soon.
SPECIAL THANKS
JRP- For the many hours you gave up to help someone whom you hardly know. For your knowledge concerning the install, and your perserverance in spite of the fact that you had a broken arm, and the fact that we worked until 4am on the morning of your birthday. (Jeez, he sounds like a war hero or somthing
). For real though, I could not have done it without you. Many Thanks.BLOWN CHEVY- Thanks for those retainer locks, bro. My car would still be up on blocks today if you had not come through. I owe you one.
jmX- For the vital tip on getting that bolt out with a dremel. You are either a genius or have been there before.
You da man, Thanks. Sorry for the long post everyone, I guess im still buzzing from the completion of all of the hard work. Take Care.
SPECIAL THANKS
A friend and I will be doing this install April 23-25. I broke the stock balancer and it did some damage to the front of the motor so I have to pull it all anyways. I am installing a FMS F4 226/226 .575/.575 LSA 112, Comp 918 springs, Comp Ti Retainers Comp Hardened Push Rods, ASP UD Pulley, MSD Wires, NGK Plugs, JWIS Timing Chain, and an LS6 oil pump.
I bought all new valve locks/keepers as well. It is real easy to loose one of those little buggers. Plus it is cheap insurance.
I can't wait to get started. Parts started showing up yesterday!
. cant wait to see the new dyno numbers after the tune. if no nobody in your area has atap/efi we can log some data with my **** when you drop off the toold.
. cant wait to see the new dyno numbers after the tune. if no nobody in your area has atap/efi we can log some data with my **** when you drop off the toold.Can you get a/f readings on efi live?
Im sure after tuning it will be just what im looking for in my daily driver. I guess we will see.
They should be fine.
