About to purchase H/C/I... Any thoughts before decision is made
#302
Yea, not my favorite thing but I'm willing to do it since Martin said the extra compression will be worth it. Sending heads to TEA today/tom and hopefully I can decide what to do with them. Im stuck trying to decide if I should run the ls3 valves.
#304
Sorry, no spedo vids, but I'll try to get some taken and posted up.
#305
You'll need at least a nitrous pressure gauge. You can also utilize a fuel pressure gauge and I recommend it since you'll be pulling fuel off the fuel rail. You can buy one of those fittings that has 2 ports in them, one for your fuel pressure gauge and one for your fuel pressure safety switch if you end up utilizing one. That fitting will screw right onto the schrader valve on your fuel rail.
#306
#308
Lol.. That bitch actually laid down 461.. But whose counting lol. Anywho, the graph looks shitty due to an RPM spike with the machine. I can PM you the results if you'd like. I wasn't even going to say anything, but if someone ask, my response is she's a monster!! I was happy with the results in my sig. (Mustang Dyno) The DynoJet is what she was Dyno'd on before the swap so to see those results were great. I'll have some track times on March 8th. That's where the real money is.
Thanks for having such an impact on the whole setup man. I appreciate it. I'm sure Clayton told you his numbers as well. That cam of his will go in this weekend.
#309
#313
P.s.- Where past this point can I pick up power? Besides Forced induction or Nitrous.
Did I mention the 4.10's and Ratech complete install kit is on its way..
Oh yea
Oh yea
#314
Ill be waiting about a month before Ill get the heads back from TEA but then Ill get the cam in as fast as possible. Id be happy if I made similar numbers to FearLS and then Ill have the 150 shot to add to it.
#316
I'm sure you'll play a part in this build as well.
Any build plans you'd like to discuss, let me know.
#317
Oh I didn't mention I have a LQ 6L block and a (Fresh) Garrett T-6 turbo. Still have to send the block off to the machine shop but the plan is 408 Turbo build with Tubular K-Member.
