rear main seal Question????
which is the better seal ?
summit has them but not sure bout quality?
thanks
The seal has very small letters on the rubber, itself (this side out), or somesuch. You can only see the letters under a light from a specific angle.
When installing the seal, make sure that it is installed all the way in-not just flush with the outside edge of the rear cover.
The seal does not require lube. I cleaned off the crank hub with citri-solv, to clear any worn rubber from the old seal. I also burnished the wear area with light emory cloth.
Install/hang the rear cover with seal, and let it center itself.
As I installed bolts in rear cover, I placed a finger under the cover, to support it. Finger-tighten bolts to hold cover in place.
Tighten bolts in steps, until you acquire proper torque.
I tried using the supplied, plastic tool, to center the cover, but found the tool was not helpful.
The oil pan is installed last.
One year, & 3500 miles later, no leaks.
How I did it no leaks, no problems. I did borrow someone's seal puller tool but gave that junk back to them. Small flathead screwdriver worked better.
As far as the seal brand I believe I just picked mine up from local autozone because I had the tranny out and wanted to go ahead and replace mine.
Don't use the plastic sleeve, and the sealing lip must not be oiled.
Russ Kemp
