New cams from Tick Performance
Old Feb 24, 2013 | 11:59 PM
  #181
Judge Smales's Avatar
Martin, Just wondering if you could run PAC 1518 springs with the Torquemax SNS 2 cam. I already have a set of those, so just wanted to see if they would work. I also have a set of 7.425 pushrods and was wondering if they would work with that cam also.
Old Feb 25, 2013 | 11:01 AM
  #182
Sales@Tick's Avatar
While I like to use a dual spring for every aftermarket cam, the PAC 1518's will work with the milder lobe option. Again, with the push rods we like to use 7.400", but the 7.425" will work fine with stock heads that have not been milled and a stock thickness head gasket.
Old Feb 25, 2013 | 11:06 AM
  #183
Thanks Martin, guess I will have to use the dual springs as I want to use the standard lobes. I will be able to use the pushrods as everything is stock. Thanks for the quick response, just waiting for tax refund to place order.
Old Feb 25, 2013 | 12:19 PM
  #184
94Z28Joe's Avatar
Just ordered the stage 3 sns setup can't wait to get it. Thanks Martin for all the help
Old Feb 25, 2013 | 01:43 PM
  #185
Sales@Tick's Avatar
You will only notice a 3-5rwhp difference between the two lobe sets. You'll get longer mileage out of the milder lobes also. I normally recommend the mild lobes to customers that DD their cars, or drive their cars a lot of miles per year. In your case, it would be to use the parts you currently have.
Not a problem!
Old Feb 25, 2013 | 02:51 PM
  #186
Martin, my car is not a DD. Its just a nice day or weekend car. That being said, could I run the stage 3 SNS/mild version with the PAC 1518 springs? Would just like to get the most out of a cam only and bolt ons with this car. My SS is a M6. Just want as much low end power as possible as it's only driven on the steet.
Old Feb 25, 2013 | 04:24 PM
  #187
Sales@Tick's Avatar
Any of the mild version SNS cams could be run with beehive springs. I just don't recommend them because if the spring breaks, you have no other spring to save your *** from dropping a valve into your motor.
Old Feb 25, 2013 | 04:32 PM
  #188
99Bluz28's Avatar
FYI Judge Smales, the stage 2 SNS/mild version does get into it's power-band at a lower(-200)rpm then the stage 3 SNS, just something to consider.
Old Mar 2, 2013 | 12:40 PM
  #189
justin hover's Avatar
To the top..copy paste didn't work for some guys
Old Mar 4, 2013 | 07:53 PM
  #190
mac62989's Avatar
Any cool stuff from the SNS stage 1 yet Martin?
Old Mar 4, 2013 | 08:21 PM
  #191
baronsmith98's Avatar
Hey martin could you post the cam cards for these cams? Thanks!
Old Mar 5, 2013 | 01:50 AM
  #192
alans67rs's Avatar
Martin, i have a 67 camaro convertible that i dropped a 5.3L into, aluminum 862 heads (stock), Professional Products Power+Plus Typhoon Intake (52061), 1-5/8" midrange headers into 2" true dual exhaust, 4l60E transmission, and 2:73 differential. A couple of forum members recommended some LS1-LS6 tick cams:
"SNS" torqueMAX Stage 1 223/227 | .61x"/.61x" | LSA111+2 (milder: 222/226 | .59x"/.59x" | LSA111+2)
Street Heat Stage 1 221/226 | .60x”/.60x” | LSA115+2
For 5.3, would these be too aggressive for a 3500ish lb car? After their initial posts they both backed off to a 212/218 duration for missing engine cubes. What would you propose would work well with stock 5.3L? This will be a daily driver, and i'm looking for the biggest midrange performance bang for the buck.
Thanks,
Alan
Old Mar 5, 2013 | 02:43 PM
  #193
Sales@Tick's Avatar
I've got a couple big lifted trucks that are installing their Stage 1 cams right now. One is a 6.0 on 37's! No passenger cars yet, everyone wants that damn Stage 2 cam! It's a popular little buggar!
What information are you looking for and I'll see if I can provide it!
Thanks,
Alan
Alan,
I would go with the Stage 1 TorqueMAX cam(223/227 .610"/.614" 111+2). A lot of people forget that the 5.3 has the same stroke as a 5.7 or 6.0 and a 6.2. Because of this it spends the same amount of time at TDC and BDC of those other larger engines and needs to be cammed similarly. Yes the bore is smaller so it will need a little smaller cam, but my cams for a 5.3 are very similar to my 5.7/6.0 cams.
Old Mar 5, 2013 | 03:17 PM
  #194
Hey martin I'd just like to see the advertised intake and exhaust duration thanks
Old Mar 5, 2013 | 03:37 PM
  #195
99Bluz28's Avatar
Thanks,
Alan
No I didn't back-off from my first suggestion, I only agreed with the other poster that with stock stall an the tall rear gears a smaller 212/218 cam would be better choice. IMO, if going with shorter rear gears and and a higher stall TC(2800-3200) won't fit with in your budget along with the cam swap, then I'd suggest going with the appropriate gears and stall first, then later when fund permit do a cam upgrade.
Old Mar 5, 2013 | 04:59 PM
  #196
alans67rs's Avatar
Alan,
Thanks for the second opinion, I'll keep this cam in mind.
Understood, and changing gears or TC before camming is solid advice that i'll need to work into my build. At least now i have an idea of a cam i can go with.
Thanks both!
Alan
Old Mar 5, 2013 | 08:41 PM
  #197
Sales@Tick's Avatar
Hey martin I'd just like to see the advertised intaked and exhaust duration thanks
The standard lobes have a 50 degree major intensity. Add 50 degrees to the .050" duration numbers and you'll get the advertised .006" durations. Unfortunately the mild lobes are proprietary.
Old Mar 7, 2013 | 02:34 PM
  #198
Ronny_02_WS6's Avatar
I just finished my build with the SNS Stage 3 mild, I will post a idle video this weekend. I won't get it tuned till later though. (street tune)
Old Mar 7, 2013 | 03:56 PM
  #199
97camaro383's Avatar
Im ready to see a video!!!
Old Mar 7, 2013 | 04:30 PM
  #200
Sales@Tick's Avatar
Well, what are you waiting on!!!!! You're killing me Smalls!!!
