New cams from Tick Performance
In your opinion which would be better for stock 243s? I am wanting a close as possible stock idle and good power.
No problem at all man! I love helping guys that are passionate about their cars! Or SUV's in your case lol!
I would recommend our LS2 Stage 1 TorqueMAX camshaft for your Suburban along with CNC porting the cylinder heads with a nice VJ as well. Since you have a LQ4 with dished pistons that the dish is 6.7cc in volume you have well over .036" more P to V than a flat top piston motor with 317 heads. Because of this you can mill at least .035" off of your heads for compression as you mentioned.
Specs on that cam are 223/231 .610"/.617" 110+2
Just for the guys that have been following this thread here is a H/C/I package we did for a LS2 6.0 GTO the other week. Tossed it on the dyno Tuesday and here's what we got:
also i no you dont like talking numbers but could you ball park hp/tq numbers on the stage 1 and 2 on my 6.0.thanks again im finally gettin close to finishing the motor parts and get my swap done.thanks again for your help Martin
Last edited by 01sub6.0; May 9, 2013 at 11:30 AM. Reason: forgot somemore questions
If you want a shelf grind then the Comp #54-455-11(215/223 112lsa+5) would also do a good job.
-PRC "As Cast" 225cc cylinder heads 62cc for a 11.47:1 SCR/8.45:1 DCR
-Tick Performance LS2 V.2 Polluter Camshaft 239/244 .62x"/.59x" 111+2 (Proves you do NOT need LSK or XE-R lobes to make HUGE power)
-Black Fast 92mm intake
-STOCK 90mm LS2 TB UN-ported
-1x7/8" Kooks Headers off road connection pipes
-Corsa Cat-back
-SD tuned on 93 octane
As far as the Stage 2, I don't think it's a good idea in such a heavy car with towing aspirations. As BluZ28 said for a stock compression motor the Stage 1 is on the larger side, but with some compression and good port work it will work very well with a 2800 stall. A GOOD trans cooler will be a must have as well.
Also, what would give me the most gains on a stock 6.0 that will soon be getting your LS1 Stage 2 SNS cam-- porting my 243 heads or FAST 102?
Maybe a truck TM line of cams for stock compression heads...?
TowMAX.....coming soon.....
