New cams from Tick Performance
Doug
They pulled my cam and it was pretty chewed up. So I'm cam shopping!
The other mods on the car are;
dum* Spec stage 3+ clutch
* Katech short throw
* BMR anti hop kit
* K&N intake
* Patriot heads
* Titanium valvesdum
* Dual valve springs
* Lingefelter 160* statdum
* Custom built plug wires
* Pacesetter headers
* Full 3" true duals
I had a GX3 242/112 in it, and it pulled pretty hard. What would be your guys suggestions to replace it with?
Which cam that you sell would work best with these heads/intake combo? I realize that a set of 3.90/4.10 gears would be beneficial but I don't want to change them at this time. I want maximum midrange tq as well as a strong pull to a 6700rpm-ish shift point, plus a more pronounced idle lope that I have now. I have a good local tuner that I'm confident can get driveability good with a larger camshaft.
Maybe the Stage 3 Torquemax with the less-aggressive lobes?
* BMR anti hop kit
* K&N intake
* Patriot heads
tonight. My only other question would is, I was told because the V is heavier, your stage 2 may give me better performance. I've not had much experience, so hopefully you could help me make my mind up between the Stage 2 and Stage 3 you guys offer.
Peak horsepower will be higher with ls1 stage 3 as will torque above 5000rpm compared to the stage 2. If you're willing to lose 10-12rwhp with the stage 2 it is a nicer driving cam and makes much more low end torque. It also responds great to compression and cnc ported cylinder heads.
Since a manual transmission has no slip, and if you go WOT with a M6 in any gear at any rpm the car is going to start accelerating from that RPM and then of course rise in RPM from there. With a stalled A4 or A3 with a 3600 + stall speed, if you go WOT with that set-up you will instantly see 3600 rpm's or more because of the stall's flash speed.
With that taken into account, the LS1 Stage 2 with it's smaller intake duration and earlier intake valve close event will make more torque at a lower RPM than the LS2 Stage 2. The LS1 Stage 2 closes the intake valve at 40.5 degrees after bottom dead center where as the LS2 Stage 2 closes the intake valve at 44.5 degrees after bottom dead center. This will move the peak RPM that torque and horsepower occur at up, along with the RPM it begins to produce "put you back into your seat torque". Because of this, the LS2 Stage 2 is well suited for a stalled automatic with a 3600+ stall over the LS1 Stage 2. You will never notice the loss of torque under 3600 rpm with the LS2 Stage 2 because the flash speed of the stall will put you above 3600 rpm every time you go WOT. Thus why the LS1 Stage 2 with its smaller intake duration, further advanced ICL and earlier intake valve closing event are better suited for a M6 or a stalled auto with a 2400-3200 rpm flash speed.
Hopefully this makes sense!
Get me some numbers on that thing Avery! When are you putting it in? I know you got all your nitrous stuff as well.
