New cams from Tick Performance
Old Apr 16, 2013 | 04:35 PM
  #321
Sales@Tick's Avatar
Originally Posted by kacivic
I think I'm going to call and see about placing an order here in just a few min... I do want to talk to someone before making a decision.
If you tried to call after 5 p.m. EST today I apologize, but we are closed already for the day. Give me a call between 8-12/1-5 EST and I'll get you taken care of sir!
Old Apr 16, 2013 | 05:35 PM
  #322
Yun Gunz's Avatar
Originally Posted by stroked383HSR
I feel your pain....Ive had 2 red tops and they both died at the 3 year mark. No pro rate or anything after that.... I was lucky to get the first one replaced for free but the 2nd I missed by 2 months...so i said screw it and got a 7 yrs Advance battery.
But Im now thinking of getting a yellow top and try it out.
LMAO, I have 3 Red Tops, they do a 2 year rotation. I threw an older one in now and see if it works. I have one in my 1969 C/10 that seems to have held a charge for a bit so that the one I threw in there. While driving I can see the Volt Gauge just slowly dip below 13 and on. Oh well, still driving the **** out of the new cam, ha. Just may need a jump if I turn it off at the moment.
Old Apr 17, 2013 | 10:27 AM
  #323
kacivic's Avatar
Yeah, I realized the time zone difference too late for it to matter yesterday, but couldn't have called before you closed anyway. I'll give you a call a little later today.
Old Apr 17, 2013 | 11:39 AM
  #324
Yun Gunz's Avatar
Tuned
Old Apr 17, 2013 | 11:45 AM
  #325
douglee25's Avatar
Sounds good man!
Old Apr 17, 2013 | 01:28 PM
  #326
mac62989's Avatar
The magnaflow tames it down huh?
Old Apr 17, 2013 | 02:44 PM
  #327
Yun Gunz's Avatar
Compared to something like your Borla, ohh ya lol.
Old Apr 20, 2013 | 09:43 PM
  #328
StormTrooperZ06's Avatar
Yea buddy just ordered the stage 3 for my z! Can't wait for it to arrive!
Old Apr 20, 2013 | 09:48 PM
  #329
stroked383HSR's Avatar
oh heck yeah....with his magnaflow its way tame...sounding that is. ;-)
congrats!
Old Apr 21, 2013 | 11:07 PM
  #330
Sales@Tick's Avatar
That's gonna be a beast!
Old Apr 22, 2013 | 11:43 AM
  #331
congrats!
Thanks man.
Oh yea man! And should i put a ud pulley as well and/or injectors?
Old Apr 22, 2013 | 02:15 PM
  #332
standerson's Avatar
I am planning on purchasing the stage 2 with a set of PRC as cast 225's small chamber 62cc.
What CR should I run with either cam? Stock bottom LS1
Old Apr 22, 2013 | 05:44 PM
  #333
Sales@Tick's Avatar
Thanks man.
Yes, we almost always install a UD pulley at the same time as the camshaft install. It's right there in front of your face so may as well do it! You may also need a larger injector as well. I'd look to at least a 36 lbs/hr or a 42 lbs/hr to cut out the guess work of, "will my stock injectors work"?
With the 227/235 110+3 Stage 2 I like to see a 62cc combustion chamber at the smallest with a .040" Cometic head gasket for increased quench. That will be a very nice combo, we are currently doing a GTO right now with the PRC 225cc As cast heads, V.2 Polluter 111lsa and a Fast 92 for a customer right now.
Old Apr 23, 2013 | 09:05 PM
  #334
greenvortec97's Avatar
do UD pulleys even do anything?
Old Apr 23, 2013 | 09:08 PM
  #335
douglee25's Avatar
They reduce the load it takes to drive your accessories, essentially freeing up power.
The one downside to this is that your alternator and water pump will be underdriven and sometimes that can cause issues with cooling or electrical charging. I stress sometimes.
Doug
Old Apr 23, 2013 | 09:14 PM
  #336
Doug
So if I already have horrible voltage issues I shouldn't do that mod? lol
Old Apr 23, 2013 | 09:21 PM
  #337
douglee25's Avatar
You have subs and amps in the car?
Doug
Old Apr 23, 2013 | 09:22 PM
  #338
Doug
no, just straight up horrible voltage haha I might need to do the big 3
Old Apr 23, 2013 | 09:29 PM
  #339
i didnt notice any coolant temp drop or electrical drop on my gauges compared to stock.
1 thing it did do was lighten my wallet but i did it anyways.
Im pretty sure it did do something cause i did most of my mods at once..so im assuming maybe 5-10hp? hoepfully.
Old Apr 23, 2013 | 10:58 PM
  #340
Yun Gunz's Avatar
I have an aftermarket system(sub, amp, HU), aftermarket tach light. After my battery from over the winter took a dump, I have had zero issues. And I run an Under drive pulley.
