New cams from Tick Performance
I can see you spinning too...I wonder how much that hurtin ya..
great runs to watch
car sounds good too! guess thats what i sound like...Ive never heard my car from the outside
I guess its just crap shoot on rearends if they can take it or not.
Im also on LS7 clutch ...so i dunno how much that can take.
I would say the spinning is killing me. (Spinnin' aint Winnin' lol)I wouldn't call the NittoNT555R's a Drag Radial in my opinion. I had them at 14psi, so that helped me hook a little more. (Some people would probably say I'm crazy for bringing them down that low) I would say the Nitto NT05R would hook better than these, and the tire I'm prolly going to next would be the Mickey Thompson ET Street Radial PRO. The ET Streets would also be a better tire than the ones I have but I'm going to purchase some Weld RTS wheels for the rear and throw the PRO on them.
Another thing which I think I did okay with was shifting, the car is a 6 speed but with the Monster Stage 3 and Tick setup/Pro 5.0/Lou's Short stick, the car shifts quick; could be quicker, but I'm just a normal guy lol
Shifting around 6500.
We had discussed the SNS Stage 2 cam but I am still torn between that and the SNS Stage 3. My goal is to make absolutely certain I hit the 450 HP mark while making as much torque as possible while keeping the torque band as low as possible with what I have to work with.
It looks as though I will have the following components to work with.
PRC As Cast 225's (with whatever chamber you recommend), Fast 92 non-ported intake, NW or Fast 92 TB, Jegs/SLP 25% UD, 3.73 gear upgrade, Bosch #42 injectors, stock GM rockers w/trunion upgrade, dual springs, new pushrods, Racetronix fuel pump w/upgraded harness, 1 7/8" LT's (undecided on brand), and Magnaflow exhaust with or without cats (undecided on cats or not).
If using a different set of heads other than the 225's would be recommended, I am all ears. Also, since this is not a daily driver, 150 miles per year so far, having to change springs every 10k miles would be fine. At the rate I drive, I would need to change springs every 66 years
.Please let me know if I missed anything and I look forward to talking with you later this week: will probably order the cam this week if I can ever decide between the two..
Q
PRC As Cast 225's (with whatever chamber you recommend), Fast 92 non-ported intake, NW or Fast 92 TB, Jegs/SLP 25% UD, 3.73 gear upgrade, Bosch #42 injectors, stock GM rockers w/trunion upgrade, duel springs, new pushrods, Racetronix fuel pump w/upgraded harness, 1 7/8" LT's (undecided on brand), and Magnaflow exhaust with or without cats (undecided on cats or not).
If using a different set of heads than the 225's would be recommended, I am all ears. Also, since this is not a daily driver, 150 miles per year so far, having to change springs every 10k miles would be fine. At the rate I drive, I would need to change springs every 66 years
Q
If I could be certain 450 hp could be made with the SNS Stage 2 cam, my decision between the two would be over and I would order the stage 2 tomorrow.Good luck on your project!
Q
Q
Q
The guys that are going to do the tuning kinda laughed when I gave them the cam specs for the stage 3 and mentioned tuning for great driving habits. They basically said they will tune it to the best of their abilities. They do, however, tune on the dyno-jet for peak performance then take you out around town and tune for max driving comfort. Something else they also recommended was a speed density tune: not sure about that as the weather is always changing etc..
Thanks again Martin!
Update: SNS Stage 2 cam has arrived!
Q
Update: SNS Stage 2 cam is on order!
Q
Here is something I figured you guys would like!
