New cams from Tick Performance
Thank you for the kind words Mark.
I went mild on the cam. Tick Street Heat stage 2. Idles nice (once it is warmed up) and drives like stock, almost. Still working out some idle bugs and the trans shift points need changed or something.
This is a 2002 LS1 camaro, LS6 intake, 799 head decked .012, Tick cam, BTR springs and lifters, used Hooker headers and used Y Pipe. FTI 4000 converter, 3.23 gear, Frost tune, everything else stock.
Not dyno tuned yet. Mail order only. There is someone close by that has a good reputation for tuning but this car shares funds with another car I use for bracket racing so it will be a couple months yet.
I have TSP 5.3 stg 2.5 heads milled 0.040. Pistons are Mahle 3.908 with a 4cc relief I believe.
LS7 Caddy race lifters, am using Pac 1518s but have a near new set of dual Patriot Gold & Ti retainers.
It is my w-end car that I road race on occassion.
The cam I have now is a NZ Kelford 222/222-561-520@112 this is giving me 408rwhp on a NZ DynoTorque, but desire more torque & HP
Dyno graf is in KW.
I am waiting on delivery of a ATI damper to replace the ud PowerBond as through bad harmonics I have previously broken a dual Rollmaster while racing.
Wayne. NZ
I have TSP 5.3 stg 2.5 heads milled 0.40. Pistons are Mahle 3.908 with a 4cc relief I believe.
Dyno graf is in KW.
Wayne. NZ
If you have aftermarket pistons with reliefs you have plenty of room for the SNS Stg. 3 camshaft. For your application it will be a great camshaft with tons of mid-range power and top end for days. It will even have great "punch" from 3500rpm and up. You will need the dual springs you possess for use with this camshaft and the Ti retainers will be a nice touch for lightening the valve train a "tick". See what I did there?
https://ls1tech.com/forums/generatio...yno-added.html
In your opinion, what cam of yours would better suit my build and still have a very mellow idle... I would like more power, but love a sleeper sound... Is this possible?
You too? Damn!
Wayne,
Is this still with the heads I have being milled 0.040.
Would your stg 3 cam increase the torque I have with my current small cam as well, you mention mid 3500rpm & up only, as I road race on occasion I still require that low torque for getting out of slow corners.
Guess I would be "ticked"
off if cars I currently beat started to pull on me till my revs came up Last edited by ls1 1990 VN; Jun 7, 2013 at 12:32 AM.
off if cars I currently beat started to pull on me till my revs came upAnother Tick Performance camshaft customer! Congrats Jesse on your new cam! This is a custom cam that I did for Jesse as it is his daily driver. He wanted torquemax like power, but something that had a little better driving manners than the Stage 2 TM cam has to offer. I settled on a 229/234 .61x"/.61x" 112+3 cam for Jesse as a great all around camshaft that will have a very broad power band while keeping Jesse happy while he DD his car!
Let me tell you, them guys at TICK are top notch.
Jonathan worked on tweaking my car and I now have a 440hp (reason 4 the extra Hp is the SSRA) car that drives 100% COMPLETELY like stock. My car is such a joy to drive now.
I put it thru all the tests and on my way home and I was able to drive in 6th grear all the way down to 1100rpm with NO! bucking at all...NONE! I couldnt believe the difference. 40, 50, 60 mph and no surging or bucking like before in any gear.
The car drives, act and feels completely like it was when stock but NOT
I hate going there (haha) cause all I wanna do is spend money. So im now going to let the wiring guru (jonathan) fix my nitrous setup and throw it on the dyno and tune it for up to 150 hit.
These guys will do what they can in any way to make (us) the customer happy campers. (just dont get to close to Martin) LOL!!!
you should see some of the rides up there. ..WOW!
thanks guys!!
thanks guys!!
I could tell how happy you were once Jonathan made those changes for you! You definitely looked like a kid in a candy store hahaha! I'm glad that you are 100% satisfied and that you're enjoying your car even more than you already have.
On behalf of all of us here at Tick, we thank you for your continued support and business John. We always enjoy having you around buddy!
, right now I'm running a tune from the hp tuners repository, it drives ok, but still would like to get a better one!!! have Jonathan dynotuned the stage 3 sns mild with heads yet???
