New cams from Tick Performance
build: https://ls1tech.com/forums/generatio...-pics-vid.html
Even though your cam seems "middle of the road" in duration size, would you believe me if I told you my LS3 Stage 3 Polluter camshaft, our biggest and nastiest flagship cam has the same IVC event your 231/239 cam does? This will mean that our larger 235/246 112lsa cam will peak at the same RPM your cam does and make damn near identical torque under the curve, but with it's added overlap will pull much harder up top.
Again it's about combining valve events that the combination needs.
That 223/234 111+4 cam will give you back all of your low end AND some along with not neutering the car past 6000rpm. The 223/234 cam will be best shifted at 6600rpm and torque should peak around 4600-4800rpm.
LS1 heads/cammed Camaro dyno 430hp/400tq - YouTube
Can't wait to see what it runs in the 1/8th now if it went 7.85 before with bolt ons and 100rwhp/60rwtq less!
I had a 224/230 cam prior..
"Man, this 224/230 cam lopes hard anyway, may as well go bigger!". So I just selected a cam at random pretty much.
I knew immediately when I hit the throttle I made a mistake. I would bet it made less power everywhere than my old cam, probably even peak too.
85mm MAF, Fast 92mm combo, 42lb injectors, SNS 2 cam, Kooks 1 7/8" headers, 3" y pipe empty cats through slp lm1 and 2 chamber spintech, yank ss3800, 2.73 rear
358.9 hp 327.2 tq
Putting off compression test for now. I just heard from speedinc something with their dyno brake was dragging and is getting fixed. Car will go back next week to see if anything changes.
I think I can be right there with b0b, if not higher. Our mods are pretty much the same, minus my stock 10 bolt.
Most all dyno wide bands read like this from what I have seen, but I'm sure there are some or a lot that don't. I feel it's all where it's positioned in the exhaust.
Bust out the degree wheel.
