New cams from Tick Performance
Old Sep 19, 2013 | 04:45 PM
  #701
matt k's Avatar
Martin, if you see this tonight and have time could you call me, I will pm you my number. It's in regards to the heads, I noticed something after I talked to you today.
Old Sep 19, 2013 | 04:51 PM
  #702
Sales@Tick's Avatar
Tune would gain maybe 10rwhp MAYBE 20rwhp if it was off.
Timing is a little high and it's a bit leaner than we run them, but I don't think it's the issue.
If the cam is found to be ground wrong I'll issue a full refund and/or have a new cam ground by comp or the company of the Crooks choice.
That said, before I'd do all of that....run it at the track.
Old Sep 19, 2013 | 08:46 PM
  #703
1bdbrd's Avatar
Martin, would it be possible to get an SNS stg 2 sized and themed cam for small bore ls3s on an ls1? Or would one of the LS3 grinds work good enough?
Old Sep 20, 2013 | 10:01 AM
  #704
CROOKS's Avatar
Putting off compression test for now. I just heard from speedinc something with their dyno brake was dragging and is getting fixed. Car will go back next week to see if anything changes.
O
Old Sep 20, 2013 | 10:05 AM
  #705
Rise of the Phoenix's Avatar
Mark off a 1/4 mile on a highway and give it a few runs and see what your trap speed is. That would be the quickest way to find out if something is wrong.
Old Sep 20, 2013 | 10:18 AM
  #706
Sales@Tick's Avatar
I am working on TorqueMAX camshafts for LS3 heads right now. Still in testing phases. Not going to release until I have solid data to go off of.
I can grind you a custom cam for now though. Shoot me an email and we'll discuss it more if you'd like.
O
Well that explains it. Should be a solid 370-380rwhp if you get a chance to toss it back on the rollers with the same tune.
Old Sep 20, 2013 | 06:50 PM
  #707
1bdbrd's Avatar
Absolutely. It will probably be in the next month or two. I want to get an idea of price and specs so I can piece together the proper setup this winter and everything I have seen from you has been fantastic from customer service to results so I'm sold.
Old Sep 20, 2013 | 11:16 PM
  #708
Sales@Tick's Avatar
I'm pretty sure I have the valve events I want nailed for the LS3 Torque Max line, but I am working on the new "TowMAX" cams for trucks as my next project to market.
Should have them ready before the end of the month and LS3 cams by the end of the year. Been trying new things with LS3 heads in the last 4-6 months with great results.
Old Sep 22, 2013 | 03:57 PM
  #709
FEAR LS's Avatar
Originally Posted by Rise of the Phoenix
Martin, my ride will be dyno'd this month; just waiting for two places to get back with me regarding how soon they can get me in. Whichever can get me in first, that's where I'm going. It's been killing me waiting this long.
I think I can be right there with b0b, if not higher. Our mods are pretty much the same, minus my stock 10 bolt.
You haven't broke that 10 bolt yet? haha I'm on my second set of axles, waiting to pick up a bad *** roller with a lot of goodies on it. (I.E 9", Meth, Suspension goodies, Set of 15" Pro Stars..etc)
I broke it with a set of MT ET Streets. I think it broke on the 2nd gear hit for the burnout, and then the 5000rpm clutch drop finished it off. LOL No mercy for the 10 bolt.
Old Sep 23, 2013 | 10:02 AM
  #710
[QUOTE=FEAR LS;17702296]You haven't broke that 10 bolt yet? haha I'm on my second set of axles, waiting to pick up a bad *** roller with a lot of goodies on it. (I.E 9", Meth, Suspension goodies, Set of 15" Pro Stars..etc)
No, haven't broke it yet. I just put on my drag setup with Mickey Thompson ET Streets not too long ago, but haven't had the car out much. When I did, I was pretty careful because those tires hook like no other. They only break loose for a split second going from 1st to 2nd.
I want to see pics of this roller. That was a great idea on your part. Probably got it way cheaper than it would cost to replicate everything.
Old Sep 23, 2013 | 02:00 PM
  #711
redtan's Avatar
Anyone running the SNS Stage 1 LS1 (222/226 111+2) cam? My buddy is looking to put something tame in his truck with the stock stall and I remembered that someone on here mentioned this cam will work well for a heavy application with the stock stall.
How's the idle and under the curve characteristics of that cam in a 6.0?
Old Sep 23, 2013 | 04:30 PM
  #712
99Bluz28's Avatar
I wouldn't run it with the stock stall, go with at least a 2800 stall TC, and with a heavy truck I'd advance it another 2-3*.
Old Sep 23, 2013 | 06:20 PM
  #713
b0b's Avatar
b0b
Heres my graph and idle after final tuning:
Old Sep 23, 2013 | 06:47 PM
  #714
97camaro383's Avatar
Congrats Bob! Looks like another badass setup with a TICK cam
Old Sep 23, 2013 | 11:00 PM
  #715
poltergeist 02's Avatar
Martin, after reading through this thread I have to ask, what cam of yours would you suggest for a somewhat (799 heads) cam only max effort setup? Also what size stall converter to go along with it for best 1/4 ET? My mods are in my sig. Thanks
Old Sep 25, 2013 | 11:00 AM
  #716
fast's Avatar
poltergeist: just email martin and have him spec you a custom. He came up with a custom for my oddball setup that I can't wait to try out.
oddball = ls1, etp 215 heads, edelbrock pro flo xt intake and ~11.8:1 compression
Old Sep 25, 2013 | 12:29 PM
  #717
That sounds like an interesting build. Awesome heads for sure. Looking forward to seeing how this setup performs. You got a build thread yet?
Old Sep 26, 2013 | 08:39 AM
  #718
Sales@Tick's Avatar
I would recommend our SNS Stage 3 camshaft and a 5000rpm stall converter.
You will love it!
Old Sep 29, 2013 | 06:48 PM
  #719
RyderTA's Avatar
Decided to throw mine on the dyno today since it was a dyno day and got some numbers. Put down 366/345, that's up 34 hp from before the cam. The most interesting thing is we found out the wideband my car was tuned with is bad, my a/f was 10.8-11.1 the entire run and we had it set to what we thought was 12.75 so there's a good chunk of power left once the new wideband comes in.
My setup is a 01 Camaro with full exhaust, sns stage 2 mild, and K&N hot air intake.
Old Oct 1, 2013 | 09:11 AM
  #720
SilverSmoke's Avatar
Hi Martin,
Shot you an email last night, not sure if your able to provide advice? - thanks!
