New cams from Tick Performance
Old Jun 30, 2014 | 11:14 AM
  #901
Mr.Goodwrench's Avatar
Any help on my spark plug situation would be greatly appreciated, I also wanted to add that i put in tr55's gapped at 0.050" when i put the engine together and it is in the car and running now, I'm just questioning my plug choice and gap for the 6.0l
Old Jun 30, 2014 | 12:52 PM
  #902
Sales@Tick's Avatar
TR6 plugs gapped@.040-.045 will do just fine. Sorry I haven't been on top of this thread lately.
Old Jul 5, 2014 | 08:03 PM
  #903
nathanWS6's Avatar
Originally Posted by FFZ28
What kind of numbers are you guys seeing out of the ls1 sns stage 2?
Look at my numbers
Old Jul 16, 2014 | 11:21 AM
  #904
KrisR's Avatar
Hey Martin,
I'm currently shopping for a camshaft for a 2000 C5 6-speed that I picked up recently. I added an LS6 intake manifold, AFE inlet assembly, catback, and have 1-7/8" longtubes and an off-road x pipe on the way to my house. Ordering an UDP soon. Current plans are to keep the stock heads on it. I do not plan on changing out the 3.42 gearset.
Looking for a cam that sounds great, drives great (including 1300-1500rpm in 5th/6th gear), will make 400+ SAE on a Dynojet with stock heads and LS6 manifold, with the ability for more potentially down the line with some good heads.
Thinking either the SNS Stage 2 or regular Street Heat stage 2. What say you?
Old Jul 16, 2014 | 06:57 PM
  #905
Sales@Tick's Avatar
Originally Posted by KrisR
Hey Martin,
The SNS Stage 2 needs a great exhaust system to hit 400+ cam only. The Street Heat 2 will be your best bet for 400+ cam only and keeping 1300-1500rpm drivability.
Some customers with good tuning report their SNS Stage 3 camshafts can drive at 1400-1500 with no issues. We have tuned several here that were able to as well.
Old Jul 16, 2014 | 07:17 PM
  #906
KrisR's Avatar
Sounds good, thank you. I'm probably ordering the SH2 package very soon.
Old Jul 16, 2014 | 08:52 PM
  #907
KrisR's Avatar
Just placed my order for the Street Heat Stage 2 LS1 cam package. Can't wait! Thanks Martin!
I think the car's gonna rock. On the same dyno that my car will be tuned on, my friend's dad's 02 Vette 6-speed did around 395rwhp SAE with a Brian Ebert 224/228 .609/.53x 112LSA camshaft, 1-7/8" longtubes and no cats (same set I just bought), stock heads and intake, Halltech CAI, and no underdrive pulley. I expect that mine should be in the 400-410ish range SAE conservatively speaking.
It did 327/335 with an LS6 manifold, AFE cai, and XSPower catback, with a tune. Stock manifolds, cats, no UDP, etc.
Old Jul 16, 2014 | 10:15 PM
  #908
poltergeist 02's Avatar
With the LS6 intake you should hit your goal.
Old Jul 23, 2014 | 08:16 AM
  #909
Sales@Tick's Avatar
Adding the headers and off road x pipe would of most likely brought you up to 345-355rwhp/350-360rwtq.
The SH2 is good for 45-55rwhp/20-30rwtq on average.
Are you doing the install yourself or is a shop? If a shop is, have them dyno it before they install the headers and camshaft for a before and after.
Old Jul 23, 2014 | 09:22 AM
  #910
M.BOZZ's Avatar
Just ordered a custom solid lift cam from Martin, can't wait to start putting this thing together. Martin thank you and talk to you soon
Old Jul 23, 2014 | 11:23 AM
  #911
Sales@Tick's Avatar
Not a problem Michael!
Old Jul 23, 2014 | 05:46 PM
  #912
BlueBird346's Avatar
Would the setup in my sig benefit from a larger than stock lid and MAF?
Old Jul 23, 2014 | 07:03 PM
  #913
I'm running a SLP lid and a GM 85mm maf. I'm happy with it so far. You should at least run a 85mm GM maf.
Old Jul 23, 2014 | 08:40 PM
  #914
Thanks I've been looking in to the 85 or 100mm MAF. Had an slp lid for a few years, just wondering if I should swap it for a 98mm.
Old Jul 23, 2014 | 09:25 PM
  #915
"MAC"'s Avatar
Well this is gonna sound a little extreme. But i dont know the flow numbers of my ported heads but was wonder what is the best cam for a supposedly max ported 241 heads?
Old Jul 23, 2014 | 09:55 PM
  #916
KrisR's Avatar
My buddy is doing the install in his home shop, and my other friend is tuning it at the same dyno facility that it put down the near-stock numbers. An underdrive pulley will be going at the same time also.
Cam and headers go in next week; hopefully by the end of the weekend it will be tuned/dyno'd.
Old Jul 27, 2014 | 10:12 PM
  #917
Sales@Tick's Avatar
Any time you have less area upstream of a larger orifice in a system like the intake tract on a vehicle it will create a restriction.
Aside from the flow numbers I need to know a good bit more information. Send an email to martin@tick-performance.com and I will email you a spec sheet.
At least the car has previously been on the dyno before. Keep us updated.
Old Jul 27, 2014 | 10:27 PM
  #918
"MAC"'s Avatar
Thanks martin i sent you an email with a that i know.
Old Jul 29, 2014 | 02:08 PM
  #919
KrisR's Avatar
Well...my cam/header project will be delayed for a bit. Sorry.
Old Jul 30, 2014 | 09:13 PM
  #920
LS7jUnKiE's Avatar
Martin, first of all awesome thread! It's good to see so much knowledge bring shared here on the forum even after all these years.
Long story short, I'm about to do heads/cam/intake on my 29,000 original mile 98 SS 6 speed.
I have TEA Stage 2 243 heads, milled 0.015 for 62cc chambers. Heads have all the good stuff, no worries there.
I just bought your SNS Stage 2 LS1 camshaft with standard lobes, I have been doing a lot of reading about PTV clearance but haven't found my specific answer.
Obviously I will be measuring during install, but want to be ready if I need to flycut. I'm hoping to be able to use .040 cometics.
What are your usual clearances with this cam and 243 heads with 2.02/1.57 valves?
I am trying to avoid fly cutting.
Thanks.
