New cams from Tick Performance
SNS2
.040 Cometics
BTR springs
BTR lifters
7.375 pr's
GM chain
LS6 oil pump
ARP hex head bolts
all other gaskets/bolts etc
My heads are
799's milled .017 to 62.5cc, CNC everything
I also have LS1 to LS6 intake swap goin on along with 3" cutout
Just another budget H/C/I but Im beyond excited, Ive been building my car from the rear forward for the last 2 years now Im finally to the fun part! Thanks Tick!
Zack
congrats! yeah man, Martin is a smart dude, Im so impressed every time I read his technical replies. He is very helpful.
Sounds awesome!!! Do you do your own tuning? I ask because I see the HPT sticker on the hatch glass.
They all work awesome with nitrous. If you're doing nothing but spraying nitrous all the time at the track or on the street I like to see a cut-off of around 200-250hp worth of jet for my N/A cams that aren't designed for heavy nitrous use. If you're wanting the car to run well on motor and on nitrous, but still want to spray a 200-250 shot, the Stage 3 camshafts are perfect. The LS1 Stage 3 TorqueMAX being what I would consider optimal for no less than 200-250 worth of nitrous jet.
Anything thing less than 200-250 worth of nitrous jet all of my N/A cams will work fine with.
Your cam is definitely not what I would consider a centrifugal blower camshaft at all. That doesn't mean you can't run your cam with a centrifugal though. Only one way to find out for sure!
It will be very interesting to see how fast you are able to go with this set-up.
Do you good folks have an LS6 replacement camshaft as would be used with long tube headers? Something with similar power range but presumably fatter curves due to improved lobes and knowledge of LS1/LS6 workings.
Something to match a typical bolt-on LS1 or LS6(LS1 with 243s and LS6 intake) and full exhaust. etc.etc.
Basically what GM would do know if the engines were in production and there was an off-road version(no exhaust restrictions) avaialble.
SNS2
.040 Cometics
BTR springs
BTR lifters
7.375 pr's
GM chain
LS6 oil pump
ARP hex head bolts
My heads are
Zack
It was GREAT talking to you yesterday as well. I know you will be more than happy with your camshaft and the performance it provides. You have a good combination with good compression and cylinder heads. It will be a strong runner for sure.
Awesome, the feeling of accomplishment you're going to get after finishing up the tune will be well worth the learning process.
If you feel like being a guinea pig, let's keep this show on the road!
I will also be glad to swap you out cams when the LS1 Stage 2 gets there if you want to trade up to the LS2 Stage 2.
Edit:
I just saw you said you just placed your order. If that is so I am going to change your order to the LS2 Stage 2.
Edit:
I think he will be fine with the LS1 Stage 2, but I'm always willing to accommodate my customers wants even if it means us having to put a cam back on the shelf that we thought we had already sold to grind another cam that they want or need.
