New cams from Tick Performance
You ordered a complete cam package correct?
This was the very next day after my complete top end cam install..everything new except the rockers and the and the heads.
You can hear it towards the beginning more so than the rest of the vid....but if you know what your listening for you can here the noisey valve train.
sometimes its louder than what you hear...It may just be me soo....but i'll have it looked at some point.
that was a politically correct answer..LOL its all good. As long as the statement above stand true Im ok with it....Ive gotten use to the noise but if it can be lesser then im good for that too. I'll bring it to the shop sometime and have it looked at. Maybe the rockers need adjusting or something. I dunno. I need a retune anyways.
have good one.
back to the nitrous install.
any idea guys?
Every video sounds amazing.
I only saw one question in here relating specifically to the 5.3, but I will ask anyway....
I have a '72 Chevelle I'm building with a 5.3 from a '99 truck. With that said, this Chevelle will be a weekend toy with some 'giddy up. I currently have a 2.73 rear but also have a 3.08 gears that I can throw in. It has a 5 speed from a BMW that I've retrofitted, so the 2.73 or 3.08's can be made to run similar to 3.42's or 3.73's due to a lower first gear. With that said, I am leaning towards the Torque max stage 2. Do you feel that is doable, or would I be better going with the stage 1?
Thanks again.
Doug
Thanks again.
Doug
With the 5.3 I would go with the LS2 Stage 1 which is 223/231 .610"/.617" 110+2. It will work much better for a 5.3 and run well with your gearing.
And you suggested this over the stage 2 ls2 for what reason? Would the engine suffer if I went stage 2? I'm also guessing that with the 110 ICL it will have a nice lope to it? Any videos of one installed?
Thanks!
Doug
