New cams from Tick Performance
Old Apr 30, 2013 | 06:02 PM
  #361
Sales@Tick's Avatar
Happy birthday! Thanks for all the business guys! We got us a pretty large SNS family going now!!!
Old May 1, 2013 | 11:07 PM
  #362
Yun Gunz's Avatar
good ol Dyno Dynamics.... just showing curves
Old May 2, 2013 | 05:20 AM
  #363
PREDATOR-Z's Avatar
Man that cam peaks early ¬5500 rpm?
Old May 2, 2013 | 05:46 AM
  #364
Yun Gunz's Avatar
5800ish, which I'm completely happy with. Prefer the low end and not revving high.
Old May 2, 2013 | 06:25 AM
  #365
PREDATOR-Z's Avatar
Dyno shows earlier than 5800, but hey you got the printout. I did not say this is bad, it must have early IVC.
Old May 2, 2013 | 07:21 AM
  #366
Yun Gunz's Avatar
It all good. It right near that point. Think I set shift light at 5800. I will go on another dyno for numbers eventually. Think it my combination of parts. No issues. Only fighting the 1" short driveshaft and leaking trans now to really enjoy. Probay have a little over 1,000 miles on the new cam.
Old May 2, 2013 | 04:09 PM
  #367
Sales@Tick's Avatar
Mark,
It has a 40.5 IVC event@.050". 65.5@.006". Normally this camshaft has been peaking at 6000-6200rpm with stock CSA and port volumes with 241 and 243 heads. With 220cc-230cc port volumes I've been seeing 6200-6400rpm peak. From the graphs I've seen James Dyno Dynamics and other loaded dynos have shown to produce a lower peak hp rpm than a dyno jet. James has a camshaft in his personal car that is nearly identical to my SNS Stage 3 camshaft that has a 46.5@.050" IVC event and on our Dyno Jet and other Dyno Jets this cam peaks at 6200-6400rpm with stock port volume 241/243 heads. On James dyno with 225cc TEA 243 head it's peaking at 6200rpm!
I think the load cell accounts for the early RPM peak along with how the load is being placed on the rollers. This is just a theory, but it seems to be the case.
I would honestly set the shift light much higher than that. I'd try for 6200-6400rpm. Car will be much faster that way.
Old May 2, 2013 | 04:44 PM
  #368
FEAR LS's Avatar
I know a James...lol
Graph on left- Dyno Dynamics
Graph on right- Mustang Dyno
Attached Thumbnails New cams from Tick Performance-james-ralph-00-ta-tq.jpg   New cams from Tick Performance-dyno-2.jpg
Old May 2, 2013 | 06:19 PM
  #369
Sales@Tick's Avatar
Didn't yours make 450 on that Mustang Dyno as well? And then later on 460+ on a dyno jet?
Old May 2, 2013 | 06:54 PM
  #370
Yun Gunz's Avatar
Working on getting on a dyno jet.
Old May 2, 2013 | 06:56 PM
  #371
second_2_none's Avatar
Originally Posted by Martin@Tick
Good deal Avery, it was good meeting you this weekend as well at the track. Hopefully the next time I see you at the track it will be to help you with the car and getting it down track!
No doubt man! Yeah it was nice meeting you as well! It should be back together in the next couple of weeks. I'm still debating on weather to get the Timing Tuner, a progressive, or HP Tuners pro. I would like to drive the car on a good motor tune, then put in some #9 plugs and a nitrous tune and tear the track up! But yeah man I cant wait to hear and see how the cam performs! I'm sure I will have a big ear to ear grin!
Old May 2, 2013 | 07:20 PM
  #372
stroked383HSR's Avatar
you aint kidding bud ....them sticks took off like wild fire. Thanks for making us a great product!
im hitting a freakin Mustang dyno.....I know my numbers gotta be up there too cause this puppy has scared the crap outta me numerous time!
Old May 2, 2013 | 08:23 PM
  #373
Yun Gunz's Avatar
Feel like the bastard child being the only one with Mild 2 lol
Old May 2, 2013 | 09:54 PM
  #374
StormTrooperZ06's Avatar
Yes, we almost always install a UD pulley at the same time as the camshaft install. It's right there in front of your face so may as well do it! You may also need a larger injector as well. I'd look to at least a 36 lbs/hr or a 42 lbs/hr to cut out the guess work of, "will my stock injectors work"?
Ok cool and what kind of 36 lbs/hr injectors you recommend and which ati pulley you think i need?
Old May 2, 2013 | 09:55 PM
  #375
Originally Posted by stroked383HSR
looks like some SNS to me....congrats!
thank you!
Old May 2, 2013 | 10:57 PM
  #376
FEAR LS's Avatar
That's affirmative! It made a whopping 461RWHP and 435RWTQ on the Dyno Jet. I wasn't showing those graphs for numbers; as you can see all dyno's are not created equal and definitely will not give the same readings. I posted those to show the 6400RPM peak!! That's whats insane, pushing it that high in the rev range and it still pulling the way it does is what truly makes that SNS Stage 2 cam ridiculous!!! I've felt it a hundred times, and believe me I'll feel it a hundred more, yet I'm so unprepared for the wrath it brings every time. SO FUN!!!
So for that Martin, we thank you.
Old May 3, 2013 | 03:52 PM
  #377
Sales@Tick's Avatar
I can't wait to see what you can do with it. I would honestly spring for the HP tuners Pro Suite so you don't have to depend on ANYONE to follow you to the track, log your passes, change timing for you etc. etc. etc. etc. You can also use timing as your traction control as well like you would with a progressive. All in one!
Did you get the nitrous install done? I bet it's NASTY!
LOL!!!
Fuel Injector Connection is the place we use for all of our injector needs. We can or they can get you hooked up.
That's freaking awesome that a 225cc cylinder head with a 227/235 duration cam can make 435ft. lbs. of torque!!! That is just awesome! The torque your set-up makes down low is just plain ridiculous.
Old May 3, 2013 | 03:59 PM
  #378
smws6ta's Avatar
Martin, 2 questions:
1) You said my cam will come directly from Comp, will I get a tracking # or order update from you or Comp?
2) With the Polluter 3 will I need to up my fuel injectors/fuel pump? Currently have the 98' stock 28lb injectors.
Old May 3, 2013 | 04:52 PM
  #379
Yun Gunz's Avatar
When I ordered my cam I got a tracking number when it left Comp.
I ran heads and cam on stock pump and injectors. They were high in duty cycle but it ran. It would be something to consider swapping out, running stock fuel parts with performance parts either delays the inevitable where they burn out, or hinders you full potential cause it maxes out.
Old May 3, 2013 | 05:17 PM
  #380
Sales@Tick's Avatar
It will come from us!
We've done them with stock pumps and injectors as long as they were 28lbs./hr. You will be in the mid to high 90% duty cycle range.
I recommend a racetronix pump kit with hotwire harness and 42lb injectors though.
