Comp pro magnum rocker issues
You could try Vinci's procedure that they developed for the Crane rockers to see if that works better. Over adjusting will hold the valves open. Also, zero lash is critical in adjustment and I prefer to gently lift the rocker tip to check clearance rather than rotating the pushrod. You could also use a very thin (0.002") feeler gauge between the valve stem and the rocker tip to set zero lash. This will result in minimal error in the final setting.
when the intake valve is 3/4" of the way closed= Adjust your exhaust rocker (0 lash, half turn)
0 lash= no up and down movement in your pushrod.
The Cranes required a 7.250" pushrod due to the rocker design. If you are using 7.400" because of its closeness to the stock length, then you need to determine the correct length which is a bit more difficult because the length sets both geometry and preload.
Are you referring to the pushrod length question or cam position? Both can be done with the motor in the car and heads on.
