higher duration?
Old Jan 6, 2013 | 12:55 PM
Ron_Stoppable's Avatar
Default higher duration?
I have a 5.3 with a 228r Comp Cam. The specs are .588 on both valves with 277 duration. Just wondering what the higher duration does? Sorry if that sounds stupid
Old Jan 6, 2013 | 01:06 PM
KCS's Avatar
KCS
Moderator
In a nutshell, it keeps the valves open longer to fill or evacuate the cylinders better. There is a lot more to it, which you can find in the "stickies" at the top of the section.
Start with this CAM GUIDE for starters.
Old Jan 6, 2013 | 02:13 PM
96capricemgr's Avatar
Also try to understand cam durations can be specified at several different lift values.
Old Jan 6, 2013 | 04:28 PM
So since mine is 277 on both valves does it make a difference in sound/lope. Is it beneficial to me since its so high?
Old Jan 6, 2013 | 05:25 PM
HCI2000SS's Avatar
Well that depends on what you define as beneficial, and yes both duration and LSA will determine the overlap thus sound that you will have. Basically more duration equals more of a rougher idle
Old Jan 6, 2013 | 06:32 PM
badazz81z28's Avatar
277 duration??
The 228R has a duration of 228/228 @.050" lift.
Old Jan 6, 2013 | 06:34 PM
bww3588's Avatar
277 is advertised. 228 is at .050 lifter rise.
Old Jan 6, 2013 | 10:12 PM
soundengineer's Avatar
in general, the more duration you have(without changing lobe separation) will give you a lopier/chopier idle
you can counter act that a little bit by making the lobe separation angle wider....to an extent... there is a point where it will start to hurt power and torque
all of these things are better explained by valve events and overlap...
which is a completely more technical discussion, that I feel is probably not what needs to happen here...
but basically, Larger Durations usually mean more peak power with the sacrifice of low end torque
larger durations usually mean larger overlap, which means more lope
Lift and duration usually follow each other to some extent to keep a certain lobe profile which will be not too aggressive and not too slow to both make power and make it less traumatic on valve springs
to put it all in perspective
a 224 cam is usually under .600 lift and most versions have little or no overlap @.050
and it sounds reasonably tame and almost stock to some people
my personal cam is a 252/274 .646/.646 113+4 and I have 37* of overlap....
with total duration of 303/328 @.006
definitely not stock sounding....it sounds more like the apocalypse is happening....
