Anybody use Same Main & C-Rod Bolts on rebuilt eninge?
Hi, heres me story, i have a 99 SS and put in a Iron 6.0, swaped out lq4 pistons for ls2s..., i sent the ls2 pistons/conecting rods & lq4 Crankshaft to get balanced.... Iv heard over and over and im not looking for opions or lessons.... That you should always use New GM Main & Rod Bolts as well as Head Bolts, either way i used the same Main Bolts and C-Rod bolts as well as head bolts for my 243s, i know bolts Stretch and i guess weaken BUT i wanna hear from someone that has Done the same as I using same exact bolts to rebuild enigine and how it ran after break in period and heavy usage or high revvin...
FYI i used Plastic Guage to verify GM Torque specs were correct and efficient for Oil Lubrication on crankshaft mains and rods i also Torqued w/ a SnapOn digital Torque Wrench to be exact i will be running 0-20W oil for the first 5,000miles if motor runs correctly and then changing to 5-30W every 3k miles or so
I want Honest Facts of people who have done the same and whete they stand rite Now
Thank You!!
Thank You!!
Ok cool thanks for all the Input... I will be doing CAM Swap probabley 10K miles after build and mildly porting 243s, head bolts should withstand by then since they torqued wel when i put em on w/o breaking, i am running 11:1 CR on ls2 pistons and 243s
Subscribing to this for more replies. These are all torque to yield bolts, which is why they are suppose to be replaced. I had no idea people were getting away with reusing them. I was going to replace all the bolts in the bottom end of the LQ4 I have laying around because I have no idea if they've ever been broken loose. I can't even find stock rod bolts for sale anywhere.
Mains and rod bolts are ok to use. Never re use the head bolts. They are TTY. Make sure to chase and blow out all of your threads and use a dab of arp bolt lube on the threads and BOTH sides of any washer. This will give you proper torque readings.
Even for the Z06 would u trust the rod bolts to 7k...for a total of $42? If so i'm in for those bolts, but maybe ARP or Katech are supirior for piece of mind. I want a bottom end that i KNOW will stay together at 7k+.
Moderator
I reuse mains all the time. Manual states to only replace if damaged. Im sure you can measure the stock rod bolt stretch and if not yielded and within spec then they can be reused. With that said. I like arp main studs, arp rod bolts and arp head studs. I have not tried reusing a stock tty head bolt. Once you break a bolt in a head or rip threads out of a head and have to get the bolt out or time cert you will do everything in your power to not repeat the process on "your own time".
TTY bolts suck even with a techwrench
