AFR 205's "Maiden Voyage"....
Gentlemen....
Took the car out late this evening after finally finishing the AFR head/cam/and manifold package as seen on our website. All I can say is the car feels extremely strong....I am very pleased. With a little chassis dyno time to fine tune things, this is going to be a great all around package. After 4500 or so, the car wants to RPM like NOW!! The tach is so far behind its almost a joke....I hit my 6800 Rev limiter so bad the first time I flew forward in the seat. It looks like a shift light is in order for the near future because the tachometer must seriously be lagging by 300-400 RPM's....at least in the first two gears when things are really happening quickly.
By the way, this was my first H/C install on a C5 and I must say all went pretty smoothly....It is certainly time consuming if you are very detailed oriented, but not a bad job to tackle if anyone else is on the fence that might be considering it.
Will have it on the chassis dyno shortly....VERY curious as to how much power we gained...(as all of you are as well!)
I will check back in as soon as I have additional info for you...
Regards,
Tony M.
PS All of you that have waited patiently will definately NOT be disappointed.
Regards,
Tony M.
good to hear.
what are the cam specs?
i can't wait to see what it puts down.
shiftlights are wonderful things. i swear my tach says 5000rpms when i hit the rev limiter in first gear
I would like to see chassis dyno results with head swap ONLY (everything else the same and eg. a TR224 cam) between:
1. Standard LS1 heads
2. AFR heads
3. Stg II TEA or AS heads (or perhaps you could do a reputable non-sponsor)
Tony, this would be a big selling point if your heads really do perform better. and I am sure that a few gaskets arent all that expensive.
2. AFR heads
!LS1 11 Second Club
I'm really sick of all this teasing. Are the heads for sale yet?!!!!!!
When and where?! Stop messin' with us. Really. I've never seen so much messin' with the consumer before. If they're good, I'll buy them already. Yeesh.
All us retailers have our initial orders in, and expect delivery within a 3-4 weeks. Afterwhich we at HPE will begin our R&D program as I'm sure most everybody else will. I expect some very serious numbers out of them...
Chuck
Chuck
Ever see so much hype before an actual install?
450 with a 224/228 cam has been creamed years ago.
Well, what I don't get is why he posts over on CF all the time. Well, actually, it's cuz they are more impressed with peak numbers, and if 't new and expensive, IT MUST BE GOOD.
How about some times? Who really gives a **** about peak numbers, and why did Tony start the post here, but hasn't put any numbers yet?
I really want to like these, but the AFR LT1s are a huge disappointment, and this has the makings of that.
Please Tony dispel everything I have said here, I really want you to!
!LS1 11 Second Club
Chuck
Chuck
"Expected delivery" has been 3-4 weeks since forever.
The best I can tell from the graphs:
hp/hp tq/tq
3000 rpms 180/190 320/330
3500 rpms 220/240 330/350
4000 rpms 250/290 340/380
4500 rpms 300/340 340/400
5000 rpms 320/390 340/410
5500 rpms 340/420 320/400
6000 rpms 320/440 280/390
6500 rpms. 310/450 250/360
hp/hp tq/tq
that was with unported afr's.........id expert quality ported afr's to go well over 500rw on stock bottom ends.
