Cam recommendation?
Old Jan 13, 2013 | 10:21 AM
6togo's Avatar
Default Cam recommendation?
Working on cleaning up a Ls6 and need a cam for it my goal it to get close to 500whp it will get all the supporting mods probably going with Prc 227 heads and the shortblock is getting dropped to the machine shop this week so the pistons could be cut very easy while there. This is a play car not a daily driver but i still want to be able to hit the road if needed but i want a nice lopey sound also! I was looking at the Ms4,Polluter,G5X3,Trex and a few others i know they will sound great but dont really know if they will make the same or more power than a smaller profile?
Old Jan 13, 2013 | 11:15 AM
garygnu's Avatar
you should contact Pat-G or Martin at Tick for a custom cam.check out the EPS website for a custom cam.what intake will you be using ?read the sticky for making 500rwhp.or search chrss1313 for his great threads on chasing the 500rwhp mark.
Old Jan 13, 2013 | 11:26 AM
6togo's Avatar
I have read most of those theads which vary allot everyone can make power with many different combo's but i was kinda leaning towards on a shelf cam. I dont have a intake selected yet but probably a fast 92 or 102.
Old Jan 13, 2013 | 11:42 AM
MIKELMOTORCYCLE3398's Avatar
Max duration, max lift, lowest lsa. -
Old Jan 13, 2013 | 12:07 PM
6togo's Avatar
Good recipe!
Old Jan 13, 2013 | 04:17 PM
justin hover's Avatar
Tell this to Martin@tick performance.
Old Jan 13, 2013 | 04:37 PM
Sail Hatan's Avatar
Martin will hook you up. I told him my goals, and requirements, and he spec'd me a perfect cam
Old Jan 14, 2013 | 06:42 AM
6togo's Avatar
Yea the new polluter V2 has my eye from Tick!
Old Jan 14, 2013 | 11:35 AM
FAD2BLK93's Avatar
My eye as well on a 111+3 lsa.
Old Jan 14, 2013 | 02:39 PM
Sales@Tick's Avatar
Just to let you guys know we offer two versions of the V.2 Polluter.
One is 239/244 .624"/.595" 112+3 and the other is 239/244 .624"/.595" 111+2.
Here is a basic bolt on T/A with completely stock 241 heads and stock LS6 intake/TB/MAF with a SLP lid, TSP 1x7/8" headers and 3" True duals before and after the V.2(112+3 version):
Old Jan 14, 2013 | 05:21 PM
6togo's Avatar
What's the difference in Lsa going to do? Any drivability issues with a A4?
Old Jan 14, 2013 | 06:48 PM
TeEnAgE pHeNoM's Avatar
Damn. I never realized the polluter had such a nice torque curve. 350+ ft lbs at 3,500 isn't bad at all for a nice size camshaft. That would work real nice with a 3,600-4,000 stall. I think it would be a great camshaft for someone with a weekend cruiser. I bet it works great with a moderate size shot as well. Good job Martin.
Old Jan 14, 2013 | 08:52 PM
Sales@Tick's Avatar
The narrower lsa will make more peak power at the cost of average power. Good for a more track oriented car or one with a looser stall converter. The customer I just showed the dyno graph of drives his at 1600-1700 in 6th gear all day long. The 112lsa will have better driving manners. If you still want similar power with better manners our new for 2013 design street heat stage 2 which is 233/240 .619/.588 112+2 fits the bill perfectly or our stage 3 saturday night special which is 235/239 .621/.624 112+2 is a great choice also.
It's got a very strong power curve from the right combination of events and lobe selection. I say it all the time the most aggressive lobe in the book ain't always the best choice. It will work great with up to 250hp of nitrous. Thanks Jacob.
Old Jan 14, 2013 | 10:08 PM
6togo's Avatar
So you saying either one of those cam will make the same power as the V2?
Old Jan 15, 2013 | 05:33 AM
Sales@Tick's Avatar
No, they won't. There is no magic camshaft that will pick up power lost through less duration and mainly overlap by going to a smaller grind. That said both of those cams will make similar power to the v.2, but they will fall short of the v.2's peak power.
Since you don't mind fly cutting as it will be very easy to do while the engine is out, have those 227 heads done with 58cc chambers and fly cut. The added compression will help make a lot of the camshafts inefficiency at cruising speeds less noticeable and more pleasurable to drive.
Old Jan 15, 2013 | 06:34 AM
6togo's Avatar
I was planning on bumping the comp. up with hopes it will help the lower rpm's and i will more than likely bump the gear ratio up to 4.10 so i really dont think at cruise speed rpm will be that low. What would be a good choice of stall speed for the V2?
Old Jan 15, 2013 | 07:02 AM
poltergeist 02's Avatar
Pat-G write up. copy and paste in this section. The "recipe" to 500 rwhp with heads and cam.
Old Jan 15, 2013 | 07:22 AM
Sales@Tick's Avatar
4000rpm at the very least.
Old Jan 15, 2013 | 08:52 AM
6togo's Avatar
Thanks I have read the PatG thread! So 4000 stall would work with these big cams any chance of using a 3600 stall?
Old Jan 15, 2013 | 09:27 AM
Sales@Tick's Avatar
If you had to use a 3600 stall I would recommend a smaller cam such as the 235/239 112+2 Stage 3 "SNS" cam or the Street Heat Stage 2 (233/240 112+2). Both of those smaller cams will make slightly more torque at 3600rpm than the larger Polluter cam, which will allow the car to accelerate faster. With a larger cam that makes less power at the rpm your stall flashes too, you won't get your car moving as quickly from a dead stop or a roll.
