5.3l biggest cam install
Old Jan 18, 2013 | 10:40 PM
onslayer80's Avatar
Default 5.3l biggest cam install
Ok, so im wondering what's the biggest cam i can install in a 5.3l stock trim. I'm going to change the springs and the intake to a ls1 intake. So, what would be the best, biggest cam and stall converter i can install without machine work to the heads. Its going into a 91 firebird with 3.73 gears and 2004r trans. no headers stock manifolds.
Old Jan 19, 2013 | 04:33 AM
mypoorLS1's Avatar
Ur not really asking the right question. Id call one of the venders and have them put a package together for you.
Old Jan 19, 2013 | 11:27 AM
onslayer80's Avatar
ok. what's the best cam i can use for max power?
Old Jan 19, 2013 | 12:05 PM
zracer323's Avatar
Peak power or max power under curve? It really depends on what you are doing with your car. With an ls1 intake you are limited on rpm, so just throwing a donkey Dick cam in there won't do you much good.
Old Jan 19, 2013 | 12:30 PM
onslayer80's Avatar
more than likely im going to drive it everyday and do some drag racing at the track every once and a while. really, my goal is a 11 to 12 second car if possible and maybe a turbo later on down the line. i understand big isnt always good. i need to find a happy medium.
Old Jan 19, 2013 | 02:47 PM
mvrotc's Avatar
not to be offensive or anything but your seemingly being wildly unrealistic and seem to be very uninformed.
Starting off with a base 5.3l in a 3500~lb car and saying i want to daily drive and go into the 11's with "the biggest cam possible" really doesnt sound like your going to end up happy.
My suggestion is to focus on a good solid build that wont push the 5.3l past its usable limit , Start with an ls6 intake thats gonna open your powerband up , id go with a 220r from texas speed or if you want something bigger a 224R , your going to need a higher stall in your trans to put that motor in the power band with a 224r, it can be done fairly cheap if your looking to keep a budget ,
Texas speed has the cam package for around 600 with springs and you can pick up an ls6 intake on here ~400 , thatll net you around 350-360whp with a good tuner
good luck
Old Jan 19, 2013 | 09:54 PM
99Bluz28's Avatar
Biggest I'd go would be a EPS TT3(224/230 111lsa)
http://www.engpwrsys.com/index.php?a...od&productId=6
Old Jan 20, 2013 | 01:07 AM
onslayer80's Avatar
thanks
Old Jan 20, 2013 | 01:16 AM
onslayer80's Avatar
[QUOTE=mvrotc;17073197]not to be offensive or anything but your seemingly being wildly unrealistic and seem to be very uninformed.
"I mention in the post 11s to 12s. With that said, im looking to be in between those numbers and i think it could be possible. im not going to bore it or spray it. stock long block only. i just wanted some input but thank you
Old Jan 20, 2013 | 09:55 AM
garygnu's Avatar
a truck intake is better flowing the a ls1 intake ,get a ls6 intake for $350 or less.you could use a fast truck intake for some more power ,but it cost $850.check comp cams for 5.3 cams ,or go to EPS or thunder racing for a good 5.3 cam.
