I talked to 3 sponsers...4 cam options to choose from. What would you do?
Old 01-21-2013, 10:52 AM
camarodude87's Avatar
TREX FTW, I DD my car
Old 01-21-2013, 04:15 PM
Sales@Tick's Avatar
Justin feel free to give me a call at anytime if you feel you need some questions answered. I'd be more than happy to go over some more things for you.
Old 01-21-2013, 04:54 PM
justin hover's Avatar
Sounds great Martin..I know I'm going with one of the SNS cams for sure now.
I'll give a call as soon as my fat *** tax refund gets here within 2 or 3 weeks.
Thanks man.
Old 01-21-2013, 06:00 PM
FAD2BLK93's Avatar
I'd go SNS as well...u mentioned the polluter, i am looking at that cam as well but on the 111 lsa. That cam sounds NASTY!!!! and 428 rw from a basically stock setup. And a quiet valvetrain...great street manners. How can u beat that? Hey Martin...how come u arn't recomending more of this cam to people???? Do u have any sound clips of the 111 yet?? Is the polluter gonna need some kinda special setup for maybe DD, or would u say track only on that cam because of its size?
Old 01-21-2013, 07:41 PM
spicebird98's Avatar
Originally Posted by 99Bluz28
IMO, get the Tick "SNS" torqueMAX Stage 3, but get it in the milder version (234/242 111lsa+2) for decreased valve train wear over all your other possible cam choices. I believe it uses Comp LXL lobes.
http://www.tickperformance.com/tick-...1-ls6-engines/
I agree with this. I like that cam. To the OP do you have a built trans or plan on it? Most of those cams are gonna need to be shifted close to 7k. If you weren't going to go with one of Martins grinds I'd be interested in seeing how a 230/238 111+3 LXL/LXL. I can see the midrange being ridiculous
Old 01-21-2013, 08:24 PM
My 4k stall and cam are going in at the same time..Yes, it is going to be rebuilt. Big spring plans.
Old 01-21-2013, 10:06 PM
James@ShorTuning's Avatar
I'd do the last one for what you want but I'm a little biased because I have the same cam only a little different LSA and ICL. Mine is a 112+2. Ran 11.30's full weight through an auto with stock heads and bolt-ons and trapped 120.7.
Old 01-21-2013, 10:27 PM
Sales@Tick's Avatar
Thanks man.
No problem Justin, take your time.
I'm glad V.2 is as big of a hit as the V.1 was and that you're impressed by it. No clips of the 111 yet, just waiting on someone brave enough to try one lol. No special set up is needed, but if your heads are milled any or have bigger valves than stock you will have to fly cut with the V.2 or V.1 Polluter.
Actually with stock heads you'd be surprised that they don't require that much rpm. If you've ever seen any of my n/a cams dyno graphs they make huge under the curve power, great average power and awesome peak power to boot. Unless a customer has a set up that can take advantage of those kind of rpms, or specifically asks for it I won't spec the cam to do that. I don't like giving up a lot of under the curve power for peak power. For example with stock port volume the V.2 peaks at 6350, shift at 6700-6800. SNS stage 3 will peak at 6200 shift at 6600-6700. SNS stage 2 will peak slightly earlier than that. Now will shifting them a little higher give faster e.t.'s, most likely, but it might not be best without rod bolts.
Old 01-22-2013, 01:58 AM
lemons12's Avatar
SNS or the 233/239..
Old 01-22-2013, 12:16 PM
BrntWS6's Avatar
Why are you getting the V3 on a 112 LSA? They usually come on a 111. If you want it to thump hard stick with a 111 LSA. Coming from a V3 owner I'd get the last one....is that the Tsunami? With a good tuner all can run smooth.
Old 01-26-2013, 06:34 AM
Ronny_02_WS6's Avatar
Right now, I have the Thunder Racing Trak Cam 231/234 112 LSA +2, But I'm worried about spending for new valve springs here in a while, So once you get your cam, you'll probably want a big one, like now I'm going with patriot stage 2 64cc heads and have my Eyeball in the Tick "SNS" torqueMAX Stage 3 milder version (234/242 111lsa+2) for decreased valve train wear.It looks very promising without having a lot of lift and smaller than MS4,TREX, etc.
Old 01-26-2013, 08:02 AM
  #32
mjs1012's Avatar
Sns. The specs look like they'd work well with your stall/gears. It probably pulls like a **** to redline.
Old 01-26-2013, 09:03 AM
  #33
PREDATOR-Z's Avatar
Old 01-26-2013, 07:14 PM
  #34
I'll probably end up with the sns stage 3 (milder). I have to go over a few things with martin yet. W2s arrived today...and that of course has funded all my mods over the last 3 yrs
And Predator Z.^^....^^^NEWBIE is the word. Yes I'm a cam newbie, thanks for all the smiles. I gotta learn somehow....hehehe
Old 01-26-2013, 11:22 PM
  #35
Sales@Tick's Avatar
I hope you didn't try to call on Friday. The weather was horrible and I went home early due to my 1 hour drive home.
If you want, give me a call Monday and we'll get everything sorted out for your new modifications!!!
Old 01-27-2013, 02:12 PM
  #36
NISSAN 240 SS's Avatar
talk to martin @ tick performance. He is very helpful and educated. he took my combo and gave me a perfect cam for my purpose. i went with the 235/243 .62x/.62x LSA 111+2. Mean sound, tabletop torque and im over 400rwhp.
Old 01-27-2013, 02:28 PM
  #37
VIPERBLUELX's Avatar
FTI Streetsweeper
Quick Reply: I talked to 3 sponsers...4 cam options to choose from. What would you do?
