Installing cam in a 155k mile longblock
When I did mine at 176k miles I did..... Cam, pushrods, springs, ls6 oil pump, timing chain, and gaskets.
I would definitely find a ls6 oil pump. My oil pressure is so much better than it was with the stocker.
Trunions would definitely be worth it if ya got the extra cheese. Also plan on a tune as well. I wouldn't pull the heads either just to put a cam in. I know some disagree because of the mileage, but unless you beat the crap out of it everytime, you'll be fine.
They're several guys on here that have over 200k with cams and original lifters.
Why in hell anyone would go through all the trouble of installing a cam and upgrading everything else, but not do lifters and trays, is beyond me.
Sure, several folks have done it. Does that make it right, or safe?
I agree its good to replace the lifters too, but not necessarily a must do. Its good for piece mind though. I'm kind of glad I didn't now after all the failed ls7 lifters that have been popping up.
Didn't want it to sound like I was disagreeing
That's really not a crazy amount of lift though, and there's plenty of good spring choices out there that won't be excessive in the spring pressure category, as well as Geoff's lobes being fairly gently on the valvetrain.
Keep us posted on what you do, as well as the results!
Texas-Speed Tsunami camshaft
Double roller timing chain
Patriot dual valvesprings
jegs pushrods
racetronix fuel pump
racetronix fuel pump harness
racetronix #42 injectors
Melling high volume oil pump
And my car also has 140k miles and runs great lol
I hope i dont jinx my self....LOL!
i'll save me some more and do injectors and fuel pump later.
I drcided against a cam just bc I don't want to risk a perfectly good motor for 40-50 whp. I decidd I'd rather spray on it.
good luck with your choice.
HUH? !!! wtf? what lifters are failing? and have they (who ever they is) come up with a reason?
and here I am replacing my perfectly working lifters on a motor that has given me NOT 1 bit of internal problems.
