6.0 for drift?
Old Feb 8, 2013 | 03:10 PM
anywereiroam's Avatar
Default 6.0 for drift?
I finally finishes my sbc build and its time to move on to. The 6.0.
It's an lq4. I really want to.get back into drifting so that's What il use it for.
I've seen it done before. People just pull out the motor and just drop in the.motor and go.
I took mine apart thinking it was bad so it wasn't.
So since its just going to be all motor would I be ok.with the same rods, crank and pistons it came with? Or would I be better of with new rods and hypereutectic pistons?
I know the crank can handle it. The hypereutectic are ok to 500hp which is around Whay I want. And the rods I've seen go bad alot.
Im.just confused as to what parts to use.
Old Feb 8, 2013 | 03:30 PM
brians91formula's Avatar
a stock LQ4 or LQ9 should be able to handle 500rwhp pretty easily if the tune and fueling is spot on. How high do you plan on spinning the motor and for how long? If anything I would probably do ARP rod bolts and a nice high flow oil pump.
From my experience it is high RPM and a lack of oil at high RPM that kills these motors. What car is it going in?
Old Feb 8, 2013 | 03:45 PM
It was going into my BMW but that went to crap.
And Ive seen the rods break.before and pushrods bend so I'd replace those I think. As far as rpm I'd imagine pretty high. Since I took it apart you think I should just re use the internals?
Old Feb 8, 2013 | 05:20 PM
monte383sbc's Avatar
just run her as is, try not to spin her to high though and put sum good pushrods in
Old Feb 8, 2013 | 05:25 PM
KCS's Avatar
KCS
Moderator
Might want to look into an Accusump for drifting. If I'm not mistaken, you'll be spending a lot of time at higher RPM.
Old Feb 11, 2013 | 05:01 PM
Alright so I'm going to just put my 6.0 together and use it as is.
Basically an overhaul since its torn down. New bearings, Arp hardware all around new gaskets.
New pushrods,new cam, lifters springs and rockers depending on the cam.
High flow oil pump. Does that all sound decent for my drift set up?
And would any of you got any advice before putting back together?
Rite now the block,pistons,and rods are in the oven getting cleaned up.
As well as the crank.
Old Feb 11, 2013 | 09:05 PM
NISSAN 240 SS's Avatar
Im building a 6.0 LQ4 for drift right now as well. they are plenty safe spinning to 6800 rpm. im running 100% stock bottom end, worked heads, good sized cam, Ls6 manifold and fueling, p&p throttle body, longtube headers, that's it. I am putting mine in a 240sx. If you've ever driven an LSX swapped drift car, they DO NOT HIT HIGH RPM. 4 to 500 hp and 350 to 450 ftlbs is plenty of power and is barely laid into to keep it sideways.
you will be just fine. but the fellas above are correct about the pushrods, get nice ones, and the fueling must be correct, make sure you dyno tune it with someone who knows their S***.
Old Feb 11, 2013 | 09:36 PM
Perfect! Sounds pretty simple. A mild build for the top
End a spot on tuning.
I was just wondering are these like old sbc rods.were
I need to recondition them?
And since the lq4 came with an auto do I need any
Aftermarket adapter or space to make it work with a t56?
Old Feb 11, 2013 | 10:07 PM
socal's Avatar
So long as it doesn't have the extended crank it will work w a t56. If you dont know is the flexplate flat or curved? What tranny was behind it 4l60, 4l80,6l80? What year is the motor 24x or 58x?
Old Feb 11, 2013 | 10:10 PM
depend how many miles on your shortblock, no mods needed for t56 it bolts right up, youll need a clutch and flywheel of course.
Old Feb 11, 2013 | 10:28 PM
Mileage is unknown. The only sign of mileage I saw was the oil change sticker.
Said close to333000 miles.but.it don't seem like it. And its a 24x wheel.
Had a 4l80e and that's all I know!
