Finally pulling the trigger on parts!
Old Nov 21, 2013 | 12:52 PM
  #761
Burken01's Avatar
Originally Posted by JakeFusion™
I have no idea. It looks like **** tho.
You won't even see it installed.
It will be everyone's little secret lol
Old Nov 21, 2013 | 01:31 PM
  #762
A.R. Shale Targa's Avatar
AMEN to that !!!!!! Kinda pissed me off too.......sent mine in clean, like new,
and then they dull the **** outta them with that media blasting crap....it's
only cosmetic I get it but they itemize that stuff on the bill and I don't like
paying for something just cuz they wanted to do it....NOT needed
Old Nov 21, 2013 | 07:30 PM
  #763
427zm's Avatar
Looking forward to the start up vid this weekend!
Old Nov 21, 2013 | 08:44 PM
  #764
Coonass350's Avatar
Originally Posted by dr_whigham
I'm curious why TEA ground off the triangle casting marks adjacent to the spark plug holes...?
I was wondering the same thing.. Oh well, wont be seen. They still look awesome though man.
Old Nov 23, 2013 | 12:12 PM
  #765
JakeFusion's Avatar
Super Hulk Smash
Ah crap. When I installed the Mantons and checked preload, I was at .057" of preload. Total travel is .058" so I cannot run 7.572" long pushrods.
So, I double checked the GM gasket I used. It was .043" thickness. So, it was close to the Cometic I was using. But I didn't fully torque down the head when I measured length. I'm guessing I introduced some preload there because uncompressed, the gasket is like .058" in thickness. The other could have been error on reading the Comp Pushrod Checker. I said it was 15 turns, but it was more like 14.75, which changes the preload about .012". Not an exact science at all, unfortunately.
So, I'm re-ordering 7.550" length pushrods from Manton. I double checked this and got 275 degrees on my torque wrench to 22ft-lbs... so that equals .035" of preload.
I guess the lesson here is to assemble the heads as you plan to run it and measure. Any changes can alter your measurements. And .010" here and .005" there add up when you're using a short travel lifter with no room for error.
Old Nov 23, 2013 | 01:10 PM
  #766
Burken01's Avatar
Can't they shorten them since they aren't 1 piece PR's?
Maybe the labor is more than new ones but its worth a shot
Old Nov 23, 2013 | 01:35 PM
  #767
JakeFusion's Avatar
Super Hulk Smash
I'll see what they say. Probably less than buying a new set.
Old Nov 23, 2013 | 01:56 PM
  #768
Coonass350's Avatar
Ah crap! I know you were ready to get it all put together man.
Old Nov 23, 2013 | 02:00 PM
  #769
JakeFusion's Avatar
Super Hulk Smash
Yeah. I went to torque down the first rocker from "0" lash and had the lifter on the base circle... and it went a full turn and a little past. I was like NOOOO!!!
So I made really sure the length is right now. And having it bolted all down certainly helps.
Old Nov 23, 2013 | 02:02 PM
  #770
Coonass350's Avatar
Good deal, so some time this week or next weekend then for it going back in the car?
Old Nov 23, 2013 | 02:04 PM
  #771
JakeFusion's Avatar
Super Hulk Smash
No, it takes like 4 days to even get it from Manton. That's Thanksgiving. If I send mine back and they modify, I imagine I'm looking at first week of December before I can even drop them in.
So probably that week I'll get it back in the car.
Old Nov 23, 2013 | 02:11 PM
  #772
Coonass350's Avatar
Gotcha. How long has your car been down so far for all this?
Old Nov 23, 2013 | 02:23 PM
  #773
Burken01's Avatar
Welcome to the wait game!!
Sucks cuz it halts the whole top end...
Old Nov 23, 2013 | 02:34 PM
  #774
JakeFusion's Avatar
Super Hulk Smash
Yep. It does suck. And I'm not dropping the engine in and then crawling up on the fender to try and reach the back cylinders. That's why I took it out. So I could do that without pain. lol
Old Dec 5, 2013 | 04:02 PM
  #775
JakeFusion's Avatar
Super Hulk Smash
Pushrods came in late on Monday and I mocked them up Tuesday. I was getting .035" to .044" preload still, even though I ordered .015" shorter. So, I chalk it up to my measuring equipment being crap. But, I did try to mate up any variance in the pushrods with any outliers on the valves. Overall, I'm in the .035"-.040" range across the board. A little more than Tony Mamo specs for these lifters, but this is a cold reading. Hot, the preload will actually decrease, so I'll be fine.
Here are some pics of the rockers installed. I put some blue loctite on the bolts and torqued to 22ft-lbs, making sure the nose of the rocker was centered over the valve. I put Joe Gibbs assembly lube on both ends of the pushrods and on the tips of the rockers to protect everything on first startup.
Old Dec 5, 2013 | 04:24 PM
  #776
Burken01's Avatar
Sweet! Coming along
I didn't use blue loctite in mine at first..
So the next day I re did it and added the blue..
Loctite makes you feel better
Old Dec 5, 2013 | 04:27 PM
  #777
JakeFusion's Avatar
Super Hulk Smash
I did the blue to seal the threads... I just worry I waited too long messing with stuff and it dried before I torqued... lol
Old Dec 5, 2013 | 04:39 PM
  #778
Burken01's Avatar
Nah it takes a whole day to fully cure.. Usually overnight
Old Dec 5, 2013 | 04:54 PM
  #779
JakeFusion's Avatar
Super Hulk Smash
There you go. Learn something new everyday.
Old Dec 5, 2013 | 05:04 PM
  #780
Burken01's Avatar
Yeah the blue is very liquid like, the red will dry hard in an hour or so
But still is best to let cure fully for 24 hrs
