Finally pulling the trigger on parts!
I did order some Bosch 13111 Oxygen Sensors... mainly cuz the old ones looked terrible when I finally dislodged them from the stock exhaust piping. I'll see how they do or if I need to go grab some NGKs.
I also ordered some DEI spark plug boot covers. I got all the spark plugs to stop touching the Kooks headers, but I wanted to have something that could shield them from the heat. The DEI covers should do the trick.
I also ordered some BMR stuff... Adjustable Torque Arm and 4L60E trans relocation bracket. The bracket came, but I'm still waiting on the TA. Not a big deal just to fire the motor, but something I'll be watching.
Also, I've been looking at rearends more closely. Strange S60 TrueTrac or Moser 9" TrueTrac looks like the choices for now. The Strange 12-bolt was also on the table, but it's more expensive than the S60 and about as expensive as the Moser 9"... The 9" would weigh less, eat less power, and be more than enough for an auto car. So I'm probably leaning that way. Tho the 12-bolt would be even lighter and probably more than enough. The other option is the MWC Fab 9... but to get POSI with that, it's quite a bit more than the POSI Moser 9"...
My MWC 9" S-trac weighs 20lbs more than the stock 10 bolt, with the aluminum center upgrade they would be about the same. I've been doing quite a bit of weight reduction and having a lot of BMR/ UMI etc parts over the years MWC suspension is by far the lightest i've seen...it's not even close.
Until the stock 10-bolt explodes, I'm not doing anything. Hopefully it'll last til the summer...
So, I bought some DEI sleeves. They were only about $15 more than the OEM heat shields, so I'd definitely recommend them.
The only problem was the FireCore50 boot. On it is a very large, elliptical shaped, reinforced push area. It's much larger than the boot and the DEIs would not fit. I had to trim this boot "grip" on the FireCore50s to fit the DEI sleeves. I guess I could have gone up one size from .750" diameter, but they fit the boot perfectly... just where you have the grip to press on is shaped weird and is HUGE. It allowed the OE heat shields to install perfectly however and rest against this boot "grip" area.
With the OEM heat shields in place, I couldn't get the wires to "snap" onto the spark plugs. With the DEI in place, I was able to easily snap the wires into place and then position them away from the headers.
See the attached.
FireCore50 boot:
FireCore50 with OE Heat Shield:
Trimmed up:
Here are the pics showing how well the DEI sleeves cover the boot and the bottom half of the wire from header heat. Seeing as how these are good for 1200F, I feel pretty confident I won't cook my plug wires.
Woohoo! It runs though and built pressure... 80psi at idle cold
I developed a problem with my daily driver tho. It started knocking and ticking when cold. It's a VQ35 in a Nissan, and they have a problem with the rear seal failing and causing that issue along with a 30psi drop across the RPM range (which I've also noticed). So, I need to get the Trans Am running so I can tear into the Nissan and see if there is any damage. Blah.
