Finally pulling the trigger on parts!
Old Dec 15, 2013 | 09:47 PM
  #821
LilJayV10's Avatar
Very nice. Jake, what did you use to center your oil pump when you installed it?
Old Dec 15, 2013 | 10:07 PM
  #822
JakeFusion's Avatar
Super Hulk Smash
I centered it using some .002" feeler gauges.
I had planned to put the headers, ignition coils, and spark plugs on tonight and run the fuel pump wiring harness up to the front, but it got too cold. So, I'll try that tomorrow.
Then, I'll be very close to being able to fire it (which I'm going to do before I install the trans)... if something is wrong and it won't fire, I'm not fighting that trans more than once. lol
But, if everything fires okay, I'll go ahead and get the radiator and all front accessories done and change the oil. It'll run on the battery for a 15-20 secs... it might not like it, but oh well. I need to see if the fuel pump will prime without the alternator though. If not, I'll at least get it installed too.
And yes. First fire will be with open headers.
Old Dec 15, 2013 | 10:32 PM
  #823
427zm's Avatar
In for the NASCAR start vid! Open headers will be fun. Your neighbors will hate you, but it'll sound fantastic!
Old Dec 15, 2013 | 10:36 PM
  #824
JakeFusion's Avatar
Super Hulk Smash
Maybe tomorrow. If it's too late, I'll wait and do on Tuesday. Then I'll get the trans installed and get the exhaust installed... then throw the rearend back into place with the new rear suspension.
And then... then! I can drive it around a little with Geoff's mail-order tune.
  #825
NnOoSsSs's Avatar
Haha yes
Old Dec 16, 2013 | 12:02 AM
  #826
Burken01's Avatar
Sweet, finally!!
Old Dec 16, 2013 | 06:21 PM
  #827
RezinTexas's Avatar
looking good!
Old Dec 17, 2013 | 08:15 PM
  #828
JakeFusion's Avatar
Super Hulk Smash
So the 1-7/8" headers slid in no problem passenger side. After getting the car what seemed to be 4 feet in the air, I could get the drivers side in... almost. I went in completely vertical, moved it around, twisted, pushed against the engine. No go.
It was hitting the steering knuckle one way and the firewall another. So, I loosened the steering knuckle and moved it up (which gave just enough space), and beat the ever living **** out of my firewall. Presto. Done. Getting to the spark plugs is now a total nightmare. Luckily, I put them in (but managed to destroy one on the last heave to push the drivers side in). After cursing everything and a trip to AutoZone, the spark plugs are all back in and torqued down.
Now, my question is - did you guys use anti-seize on the grade 8 bolts for the headers? Seems like that would be a wise thing to do. Also, is 18ft-lbs on a two pass sequence correct? That's what it was for stock. That correct for the headers?
Now the eye candy:
 Michael S. Palmer
Old Dec 17, 2013 | 08:34 PM
  #829
LilJayV10's Avatar
I think that's the first time I've heard of someone having to beat their firewall up using Kooks.
Old Dec 17, 2013 | 08:35 PM
  #830
JakeFusion's Avatar
Super Hulk Smash
It was wedged up against it good. I had just tightened down the pedastal mounts, but I was about to unbolt them and jack the engine up to try and get separation from the firewall... Turns out the massaging worked.
Old Dec 18, 2013 | 06:35 AM
  #831
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Well look whos name is all pretty and green...
Old Dec 18, 2013 | 07:43 AM
  #832
JakeFusion's Avatar
Super Hulk Smash
Ha. Yup.
You out on the rig for Christmas?
Old Dec 18, 2013 | 08:07 AM
  #833
Rise of the Phoenix's Avatar
How much Coors Light did it take to make that happen Dave?
Old Dec 18, 2013 | 08:34 AM
  #834
427zm's Avatar
No kidding! Nice Jake, glad you've been welcomed in!
Old Dec 18, 2013 | 09:27 AM
  #835
SteelCityYaga's Avatar
Yes, use anti-seize on your header bolts, preferably high temperature anti-seize.
http://www.permatex.com/products-2/p...bricant-detail
I used anti-seize on every bolt that didn't require Loctite, sealant or ARP Lubricant.
Old Dec 18, 2013 | 09:32 AM
  #836
dr_whigham's Avatar
The Scammer Hammer
Quoted for truth.
Yes, I'm out here. Supposed to be going home the 31st, but I might possibly stay on the rig to go to the Bahamas to pick up a new BOP. All 330 tons of it. Depends on when they decide to depart.
Old Dec 18, 2013 | 09:36 AM
  #837
JakeFusion's Avatar
Super Hulk Smash
Good to know on the anti-seize. I've been of the mindset that if it goes into aluminum, it probably needs anti-seize.
Old Dec 18, 2013 | 09:46 AM
  #838
A.R. Shale Targa's Avatar
Except spark plugs for nitrous apps....no like-ee
Congrats on being the new sheriff in town..........
Old Dec 18, 2013 | 10:44 PM
  #839
LilJayV10's Avatar
I think I'm the only one that uses it at work. If you aren't concerned about the next guy that might have to take it apart don't use it.
Old Dec 19, 2013 | 12:35 AM
  #840
Burken01's Avatar
If its a zinc coated spark plug it doesn't need anti seize, this is NGK's advice..
