lq9 oil pump functionality?
Old 02-11-2013, 03:16 AM
Brian'sCharlotte(TA)'s Avatar
Default lq9 oil pump functionality?
I'm wondering if it's possible to run the stock lq9 oil pump/timing chain set up with a cam swap. The cam is the TSP 233/239 in a bored .030 lq9 with ls3 heads. Basically just wondering how necessary it is to upgrade to a double chain/ported pump of some kind. The pump, timing chain/gear, and engine, only have about 3k on them since the rebuild.
Old 02-11-2013, 03:23 AM
PREDATOR-Z's Avatar
yes you can.
Old 02-11-2013, 03:24 AM
Burken01's Avatar
It isn't totally necessary, just good insurance since everything is already apart, most people replace timing chain, lifters, oil pump...
IMO I would just because I'm upgrading.
Old 02-11-2013, 03:46 AM
PREDATOR-Z's Avatar
If money is not to be wasted and for such a standard cam, what you have will work fine in the proper rpm range.
Old 02-11-2013, 05:21 AM
Yeah, that's more less what I was thinking.. What would be a safe RPM range to keep the motor on with that set up? I was debating going with the ARP rod bolts for a little extra spin but I don't want to jeapordize breaking anything. I'm really in all honestly looking for 6500+ but not over 7000 rpm. The lifters, pump, chain, and gear were all replaced in the rebuild. But if needed for such revs, I'll just go ahead and upgrade to a ported pump and ls2 timing set up.
Last edited by Brian'sCharlotte(TA); 02-11-2013 at 05:22 AM. Reason: forgot lifters
Quick Reply: lq9 oil pump functionality?
