Bigger cubes, 5.3 do-able??
Never done an entire motor before but I'm kinda looking to do a Nitrous 370 or 408.. I just ran across a 5.3 block locally for 25$! Is there any disadvantages to getting a small block like this bored to those cubes? I really have no idea if its even possible, just trying to get some insight on what is possible with this block.. Guess my question is will it effect cam size, stroke, any of these things?? Enlighten me please.
Predator..th never asked the guy if it was iron or aluminum. He did say lm7, I assumed it was iron?? Would either block be better for my goals?
But whether it's a 4.03 off the shelf piston or 3.903 off the shelf piston doesn't matter, they are the same in price. So overall, a 383 stroker kit is about the same as a 408 stroker kit.
The 370 is different as that uses a stock crank, so should save you some 6-800 bux over a stroker kit.
675 bucks
I have a ls1 crank,rods,pistons "that are to small" Can I use my crank and rods with new pistons with this block?
How about my 241 ls1 heads, would they work? and if so will my compression suffer?
I am new to ls engines, but cant wait to put one in my 78 Corvette.
