important hydraulic roller cam/ spring breakin info!!!
I have been told many many different ways to "break " in your new cam and springs and what my research has found is that's its all B.S there is no such thing as heat treating no reason to uninstall the inner spring and re install ( on duel springs) as a matter of fact the only thing you have to do is get the car to running temp 160-180 and rev away...
Called Texas speed very nice company great customer service will be doing business again but they told me to heat cycle no such thing.. comp cams told me to remove inner spring no need for that so I got the number for the manufacturer of comp cams and they gave me the low down dont believe me call your self the tech guys for comp cams will gladly give you the number... Now no more worries about how break in hydraulic roller cams
Hydraulic roller cams don't really have any actual break in. Just lots of lube till the oil pressure gets there. As far as Valve springs im with outkast on this one. Im not 100% sure if there is an actual heat cycle period for the metal or not but i do now that if you get on it hard right away on cold *** heavy duty valve springs you run the likelihood of breaking one
[QUOTE=outkast6991;17188521]I don't know about the cam but you should be putting the springs through a couple heat cycles for sure[/QUOTE
I asked the manufacture about heat cycle he said there's no such thing the springs are heat treated on the process of making them but you must brng them to running temperature before you rev the motor
Your engine doesnt get hot enough to "Heat treat" anything and there is no controlled cool down. When I first started up my engine, the cam and springs were the least of my worries. As long as its lubricated, you shouldnt have any issues. Its the flat tappet lifters that can ruin your day in a hurry if not broken in right.
