What size piston rings do i need?
Thanks
If their honing your stock 3.898 bore for instance to 3.905 then you would need a 3.901 sized piston for it to have a .004 piston to wall clearance for a NA motor...
So it all comes to how much they are taking out of your cylinders. Call them and ask 21 questions lol
Are you using stock pistons? You can't hone out your block too much or else you need bigger pistons
He says he just wanted to ball hone it and be done.
I guess it comes down to your budget, just a heads up for next time you build your engine.
goodluck
