I Missed A Shift!
Old Apr 21, 2004 | 09:44 PM
amit's Avatar
Default I Missed A Shift!
was going for 4th gear and missed and went into 2nd! i was at redline when i shifted too. my tranny seemed to jerk quite a bit when it happend! i heard a big "KA-DUNK!"
i quickly stomped on the clutch almost imeediataley.
the car seems to run fine though it didnt stall or anything. im afraid i might have bent my pushrods but am not sure. is my car gonna be ok?
HELP!!
Old Apr 21, 2004 | 09:55 PM
Ferocity02's Avatar
Pull the valve covers and rockers and check... I would if I did that. Take out the push rods and roll them on a flat surface to tell if they have bent.
Old Apr 21, 2004 | 10:05 PM
amit's Avatar
how long will it take to do that?
Old Apr 21, 2004 | 10:15 PM
gonbad's Avatar
It will take a couple of hours per side. You will have to remove the rockers and pull each push rod. Roll them on a flat surface and see if they are straight. I would pray if I was you.
Old Apr 21, 2004 | 10:47 PM
mikes02ls1's Avatar
I did the same thing last year at commerce. Was trying to go into 4th but hit 2nd, after that I imedaitaley pushed the clutch in. My car has felt the same since I did the rookie shifting. with my Nittos I now hit my best @ 13.2@106.95 so i have to say my car is still strong. Your car should be OK enjoy... Also no problems with the car, no SES what so ever..
Mike
Old Apr 22, 2004 | 05:39 AM
Hannibal's Avatar
I would THINK that if you bent some pushrods you would know it. Get a tap or something from the motor - at least a little clicking or something and possibly an SES light too. It doesnt hurt by any means to pull the PR's and check them. Its really not hard to do at all (looks scarier then it is) and 2 hours should be plenty of time.
Roll them on a pane of glass (glass table top) and you will actually be able to hear if they are bent as the wobble as the roll across the surface.
Old Apr 23, 2004 | 09:36 PM
amit's Avatar
thanks guys.
i got no ses lights or anything. im gonna pull the pr's this weekend. i think everything is ok but it doesnt hurt to look.
Old Apr 24, 2004 | 06:58 PM
pdd's Avatar
pdd
good luck
Old Apr 24, 2004 | 07:15 PM
Scalpel's Avatar
Possiblities:
Bent pushrods
Bent valves
kissed the pistons
Busted valve guides
Old Apr 25, 2004 | 02:17 PM
mike c.'s Avatar
don't do that again. i did it once,no problem. i did it twice it broke a piston and spun two berrings. i had agostino build me a new forged short block. i think i may swap to an auto next year,no missed shifts with an auto. goodluck to ya.
Old Apr 25, 2004 | 02:38 PM
demonspeed's Avatar
It's not mine! woo hoo!
I wouldn't worry unless the thing was making a racket. I mean, you couldn't bent the push rods, but if it's not ticking you're probably ok. The thing is, when you bend a PR, I don't think it'll set the SES light. When you pull out some of those bent rods, you'll be thinking how the heck the thing ran. I've seen a couple really nasty ones, but the car ran pretty good.
Old Apr 25, 2004 | 10:48 PM
70 TA's Avatar
I did the same thingran up to 5500 RPM in third and jammed it into 2nd saw the tach max out past 7k for a brief moment before I pushed the clutch back in.
Scary stuff back tires skipped a bit, could lose control like that or blow up the rear end
Car still runs real hard it was a week ago so I'm thinking everything is ok.
I've order a B&M ripper shifter in hopes that once its in it never happens again.
I've driven a lot of manuals and have never had this happen and I'm surprised to see that several people on the threads here have done the same.
Old Apr 25, 2004 | 10:51 PM
RaNsOm's Avatar
if theres no SES light or tapping then your ok...Ive done the dreaded 4-2 shift THREE times when I first got my car and I never bent any pushrods
Old Apr 25, 2004 | 11:00 PM
black_z's Avatar
Your a lucky bastard redhot, I did it once, but it was only at about 4K in 3rd.
Old Apr 25, 2004 | 11:25 PM
amit's Avatar
well i pulled the pr's today and even though my car seemed to be running fine, some of the pr's were bent!
Old Apr 25, 2004 | 11:30 PM
70 TA's Avatar
So your saying your car still ran hard up to redline even with the bent pr's?
Old Apr 25, 2004 | 11:32 PM
hepcatws6's Avatar
HELP!!
Chances are you will be ok, but it never hurts to check- better to err on the side of safety! When I was younger I accidentally dumped a car into reverse from drive and it was fine after, no problems...but, like I said, it wouldn't hurt to check it out anyway.
Old May 3, 2004 | 05:57 PM
amit's Avatar
yeah i guess. not all of my pushrods were bent. some of them were bent but nothing drastic.. i rolled them on a pane of glass and they were a little wobbly.
