oil pressure in relation to the PCM
Old Apr 3, 2013 | 10:41 PM
3rdCoastPowerSports's Avatar
Default oil pressure in relation to the PCM
does the PCM have to see oil pressure in order to work properly. I am working on a hybrid that has the oil pressure sensor removed and a mechanical gauge put in its place. Motor just cranks and cranks. I remember reading something in the FSM a few years back about the computer having to see at least a few psi of oil pressure before it will allow the motor to start. Is this correct? or can you completely remove the oil pressure sender and install a mechanical gauge without running in to any issues?
Old Apr 3, 2013 | 11:38 PM
OhTwo's Avatar
I think it should work without seeing oil pressure. I broke my sending unit when I did my heads/cam swap and as I remember it started but showed no pressure which is when I discovered I broke it putting everything back together.
Old Apr 3, 2013 | 11:43 PM
im-not-guilty's Avatar
This is a ls engine not a lt1 engine correct
Old Apr 4, 2013 | 06:51 AM
gagliano7's Avatar
I put a 2004 5.3 with a 1999 pcm in a 1992 chevy pickup and i have the trucks oil pressure sending unit installed. I have no oil pressure signal going to the pcm and truck runs fine.
Old Apr 4, 2013 | 09:14 AM
moeZ28's Avatar
The pcm does not read oil pressure...only goes to the gauges.
Old Apr 4, 2013 | 01:11 PM
badazz81z28's Avatar
Yup, PCM will work just fine.
Old Apr 4, 2013 | 08:51 PM
sweet99ss's Avatar
Yes you can unplug it and it will still start
Old Apr 5, 2013 | 07:01 AM
moeZ28's Avatar
Check all your grounds...especially on the back of the driver side head. There are two ground wires there, but there are 3 eyelets to be grounded, not two. Make sure you got all 3 or it wont fire.
