What's up with Comp Cams ?
Here is a "rah-rah" article from 2011, BEFORE these problems appeared . . . Makes me wonder how much was only "HYPE", given what we see now.
http://www.practicalmachinist.com/vb...hining-237600/
I'm sure that Comp will fix things, eventually, but I won't trust their cams for quite some time, until enough time has passed that the "old units" are gone from vendors. That would probably take at least 2 years, possibly longer.
Is there an issue? Possibly. Is it related to their process? Probably not. QC would be an audit of the process. QA would look at the broader problems and determine if the process, materials, surface hardening, polishing etc were the culprit. But they'd need to do a root cause analysis of failures... Which so far has not be acknowledged that there is even an issue.
Not a camshaft failure but it left me with a lasting bad taste for Comp products. My current build has a Lunati core.
I am sure they will do the stand up thing once they have determined what the problem is.
The problem did not show up in newer cars because they employ a roller cam instead of the flat tappet. But street rod guys and engine builders were running into problems they’d not had experienced before.
First off, the cams themselves are somewhat soft. They need to be heat cycled which will season it, making the metal on it very hard and resilient to wear. It also needs to be broken in. That is each lobe on the camshaft is mated, so to speak, to a lifter. All the little imperfections on that lobe need to match all the imperfections on the lifter and that usually takes place within the first 15 to 20 minutes of that engine’s run time. So when you first start it, all of this is going to take place and that break in procedure produces heat. The lobes on the cam are not pressure lubricated like the bearings in the engine would be. They’re splash lubricated so they’re getting run off oil from the cam galley, getting splashed from the crank shaft when the engine is running. Because that’s all that lubricates these parts, anti-wear additives are critical in this area.
Gotta love the imported stuff.
http://www.barnesgroupinc.com/about-bgi/locations.aspx
You can't just blame the vendor, Comp may have cost reduced the spring in more ways than just a vendor change.
And frankly, I've designed alot of products and put them into production, and I find quality control out of lower cost geographies is really no worse than quality control out of the USA. This is first hand experience.
