What's up with Comp Cams ?
Thanks Geoff and Kip you guys are the best, and best of all that whine is gone!!!!!
As for the cam itself, if you send it back, they should polish it for you. Or, you could just put a Cam Motion cam in it. They polish all of their cams after grinding as standard procedure to assure quiet operation.
COMP is probably the top selling cam so you will have more people with issues, more cams sold the higher the percentage of people with issues. Not everybody breaks them in properly either, I've seen people first hand do this,they get the cam installed and want to rev this **** out of it and go drive it hard right away to see the New cam in action.
Anything mass produced will have a higher percentage of feedback and somes gona be negative. And a higher number of bad cams slip through QA.
Just like When you pull a brand new part out of the box from another performance company and it's bad, it happens. And usually is corrected with a new part from the company,
I had a brand new pcm from gm bad out of the box. So does that make GM bad? Of course not
I hear you on the pcm thing. But if there was a 27 page thread with people getting DOA pcms. Would you agree that the manufacturer of the pcm (delphi) had an issue? Of course you would.
Now granted as you said cam motion is a smaller operation however they did have an issue similar to this in 2006, realized it, and then corrected it. Since then not one complaint. Now comp has the same issue but instead of admitting there is a problem and rectifying it at the source they simply send out cams with a pretty high failure rate (evident by this thread) and only fix it when a gun is put to their head.
I invite anyone here to get in contact with comp customer service and see how helpful they really are. Especially when you have an issue like this an no big name sponsor backing you. I'll give you a hint, they SUCK.
Comp obviously is turning out good cams because this thread would be even longer if not. How its still unacceptable. For me the evidence presented here and elsewhere about the QC (whining, cam's hardening coming apart, cams being ground several degrees off) would lead me to go to cam motion which uses a better 8620 cam core to start with and doesnt have these issues.
This doesn't mean your wrong because there are obviously people having problems backing you up. But that doesn't mean comp cam is forever junk, I'm sure they will, if not are already fix the problem,
since they don't plan to stop making cams
I'm sure they will satisfy any customer who bought directly from them and not used or anything, but I'm not 100% on that as I've never had a problem to call them about. Glad I didn't get a bad one lol
