LS Rocker Arm Bearing/Trunion Comparison
#44
Thats a lot of spring pressure on stock rockers. Not sure how much the trunion kits should handle but if IIRC Brian Tooley recommends not going over 400lbs with stock rockers because it will wear the valve and rocker tips.
#45
Harlan sharp used to (might still) offer rocker trunions, and they admittedly had a heat treat issue. Looks exactly like my comp ones did, except comp wouldnt fess up to it.
https://ls1tech.com/forums/generatio...cs-inside.html
Some other failure threads
https://ls1tech.com/forums/generatio...g-ls2-gto.html
https://ls1tech.com/forums/generatio...e-problem.html
http://lsxnation.net/forum/showthrea...-you-comp-cams
http://lsxnation.net/forum/showthrea...our-f-trunions
#47
Lunati sells a retro-fitted stock rocker, not sure who the supplier for the trunion and bearing is. Anybody know anything about these? FWIW colorado speed sells them out the door for 268 and no core charge.
I had heard about these failures prior to upgrading my own, but chalked it up to some one off incidents. I pulled mine about 100 miles ago to go with shorter PR and all snap rings were in place, all rockers rolled smoothly.
I am using BTR platinum duals...
#50
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Why do I need to upgrade rockers? (There are none that will work with my heads, but I'd like to hear your logic)
This car isn't a driver. It sees ~2000 miles a year, tops
#53
Super Hulk Smash
Sky high springs pressures would put a lot of stress on the whole rocker assembly. Not saying it caused it, but I wouldn't be surprised if that didn't contribute to it.
Like I said before, the LS7 guys have seen more issues than anyone with stock and upgraded rockers. Their springs, cams, and offset intake, and 1.8 ratio all are at a level above where most of us LS1 guys play at. Maybe with BTR springs, endurance type lobes, and lightweight valves, you wouldn't see this problem. Or it'd take a lot longer to notice it.
#55
Super Hulk Smash
480lbs is a lot for the application. No need to run those kind of spring pressures. You aren't running BBC valves that weigh 150g. But maybe you needed it, I don't know. If so, you're case becomes an outlier for what the trunion upgrade was designed for. Still doesn't mean there aren't any issues...
#56
Has any of the metals in question been tested for hardness?
If not all of this is hearsay.
For what its worth i have been rocken the comp trunions in my personal ride for the last year (around 12,000 miles). For the last year i have also been rocken a Comp cam cut on LSK lobes. I have 400lbs pressure. No issues what so ever. I even R&R the valve springs 3,000 miles ago checked everything out, everything was good to run.
#58
You also don't have 4xx pounds of seat pressure, you would pull the keeper off the valve when it opened... lol. 400+ open most likely.
Keep in mind my rockers were all working fine when I discovered the issue, and would likely still be working fine today. Doesn't mean the issue isnt there.
I didn't rockwell the trunion/bearings, because I don't give a **** about it either way. Not giving comp another chance to trash my engine
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#59
There's still thousands of comp cams trunions out there surviving just fine on some very healthy cammed cars. When you make thousands of anything there's always a chance some may not get heat treated correctly. If a bad batch got out I wouldn't call all their products trash. Ive had no issues with my comp cams cam I installed last July. I bought the trunion upgrade kit months ago and just got to install them so we'll see how they go. My spring pressures are 475lbs open.
