ARP head studs into 6.0l block, extremely hard to thread in, problem?
It took about 5 minutes each to do 2 studs so far. every stud was like this, would only thread in a few turns by hand then you can try and use the allen to slowly work them into the block (by tightening/untightening and they slowly work thier way down).
Any possibilities on why?? The threads seem clean as they can get. I put a bit of oil on each stud to lubricate it just a bit. I'll try some ARP moly lube i picked up tonight but i really doubt thatll make it easy to hand tighten thead in.
I would not use any oil or grease substance as it may crack the block.
Kurt
try runnin a tap in one and see if it gets easier to thread in.
the moly lube is your best bet for torque readings. ive never had a problem with motor oil on the bolts cracking a block, aluminum or cast iron, head or mains.
I'll try brake cleaning them out again and blowing them out.
And ARP Moly lube
argh
Unfortunately, Time Sert (where I got mine) will no longer sell the LS1 thread forming tool. Some bone head broke the tool off in a block and is suing Time Sert for a block. I don't know off hand where you can get one but perhaps ARP knows another company that makes a thread forming tool for the LS1.
Steve Demirjian
Race Engine Development
i have only used it on northstar aluminum blocks, never ls1. but they doo make a kit for ls1 i saw one on ebay.
you have to drill the old treads, tap(or whatever its called) then thread in a new time-sert. northstars suck *** by the way.
but this is an iron 6.0 block right? i dont see why you cant tap the holes.
i dont think you will hurt the block by running them in.
seems to have worked for "btl fed"
