862's vs 853's
Old May 6, 2013 | 07:04 PM
Treyvs's Avatar
Default 862's vs 853's
I need some opinions on what to do. I plan on EVENTUALLY running a procharger with a mild shot of nitrous. Until I have money for the procharger, the nitrous will be all that is ran. This is on a 5.3L LM7, so what should I go with, my stock 862's or the 853's I just bought? Which one is better for either application? I know the 853's will lower the compression considerably, so for N/A means it will may fall on its face. Let's hear it!
Old May 6, 2013 | 07:12 PM
HCI2000SS's Avatar
The 853's are stock as well?
Old May 6, 2013 | 07:13 PM
Treyvs's Avatar
Yes sir, both are stock heads. The 853's have 40K on them while the 862's had around 117K.
Old May 6, 2013 | 07:17 PM
HCI2000SS's Avatar
I'm certainly no expert here, but from my understanding (since we are comparing stock to stock) the 853's will be a little better
Old May 6, 2013 | 07:19 PM
Treyvs's Avatar
Won't the bigger combustion chamber make it fall on its face when it's just ran N/A without the help of the procharger?
Old May 6, 2013 | 07:29 PM
HCI2000SS's Avatar
Well from what I know even though the 862's have a smaller combustion chamber they have smaller valves and a poorer flow rate in stock form, thus offsetting the compression bump
Old May 6, 2013 | 07:33 PM
Treyvs's Avatar
Point taken. Anyone want some 862's? Lol
Old May 6, 2013 | 07:36 PM
HCI2000SS's Avatar
Well don't just take my word for it totally lol. Like I said i'm no expert, but I have heard this said before.
Old May 6, 2013 | 08:19 PM
Treyvs's Avatar
It makes sense, especially in the higher RPM's when the engine really needs all the air it can get.
Old May 6, 2013 | 08:49 PM
LS5.3stang's Avatar
Casting Numbers 241, 806, 853
Head: 1997+ LS1 5.7 Liter Passenger Car
Material: Aluminimum
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2000-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 66.67 cc------0.100--0.200---0.300---0.400---0.500---0.550--0.600
Intake 200 cc------------67----122-----178-----215-----219-----223---227
Exhaust 70 cc------------52-----97-----133-----156-----170-----76----180
they flow almost the same. the 862s have a better design to get only outflowed by 1 cfm with smaller intake valve
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
heres the website http://houstonperformancetrucks.com/...h-flow-numbers
