Valvetrain breakage
Old Jul 8, 2013 | 01:37 PM
Roarin_8's Avatar
No I didn't speak to Brian about the patriot springs. Good thing they went out of business or else this problem could still be happening with other cars.
Old Jul 15, 2013 | 09:05 AM
Roarin_8's Avatar
More pics, had 10% ATI underdrive pulley installed and had the A/C done as well, A/C pulley is NOT underdriven.....
Old Jul 15, 2013 | 09:06 AM
Roarin_8's Avatar
243 Heads with Brian Tooley valvesprings
Old Jul 15, 2013 | 09:07 AM
Roarin_8's Avatar
LS6 Valley Cover
Old Jul 18, 2013 | 08:25 AM
Roarin_8's Avatar
Rear knock sensor coated with oil
LS2 lifter trays
243 heads on
New waterpump with 160 degree T stat
Replacement rockers on
Valve covers back on
MSD Wires with new spark plugs
Cleaned up hoses and radiator support
Car is going to be fired up today and I'm picking up on Saturday.
Old Jul 18, 2013 | 11:34 AM
TurboBuick6's Avatar
What is different about the two springs? Any one really know? or they just are? Like rainbows and posi tracks on a plymouth.
Old Jul 18, 2013 | 10:02 PM
vettenuts's Avatar
Not sure what you are running for oil, but the new SN oils won't protect with with the higher spring forces and loads we are all running in our modified cars. I switched the Amsoil Z-Rod for this very reason, it still maintains the older ZDDP and phosphorous levels to protect these highly loaded parts.
Something to think about with your new setup.
Old Jul 19, 2013 | 06:31 AM
Roarin_8's Avatar
Originally Posted by vettenuts
Not sure what you are running for oil, but the new SN oils won't protect will with the higher spring forces and loads we are all running in our modified cars. I switched the Amsoil Z-Rod for this very reason, it still maintains the older ZDDP and phosphorous levels to protect these highly loaded parts.
Thanks for that, oil is always on my mind
Car is up and running, mechanic says it sounded great and the A/C was blowing cold. Also stated I need a slight tune to control the start up idle which I already knew I had to get especially with these new heads. Picking it up tomorrow.
Old Jul 19, 2013 | 12:43 PM
Roarin_8's Avatar
All done
He's even going to wash the car so it will be nice and "purdy" when I pick her up
Old Jul 20, 2013 | 07:47 PM
Roarin_8's Avatar
Car needs a tune but other than that, sounds very good, a bit deeper sounding than before.
Old Jul 21, 2013 | 09:38 AM
96lt4c4's Avatar
I would not run that 160 degree t stat. Run it stock temps.
Helps burn contaminants out of the oil and allows parts to expand like they are meant to.
Old Jul 21, 2013 | 09:55 AM
  #32
96lt4c4's Avatar
Brain did spintron testing on the Patriot springs and the results were not good. The springs could not even handle the cam they were using at idle. Was not an aggressive cam either.
Old Jul 21, 2013 | 10:44 AM
  #33
Roarin_8's Avatar
Fans haven't been calibrated for the 160 T stat so it still goes to 225 operating temp, was watching the temp on my aeroforce gauge. Once I get the tune, I'll have the fans come on around 175. I do live in hot Florida after all.
