Clanking/Metal Grinding when starting!
I've only cranked it for half a sec or two, didn't want to keep cranking and damage it more. The night before this happened, the car drove fine, there were no signs of any issues or anything.
The car is a 2000 Z28 with auto trans, no major modifications except for a cat-back exhaust, with about 160k miles.
Only major issue with the car is that I cannot put it into 'park.' I have to leave it in neutral and pull the e-brake. This happened after a trip from Houston to Lubbock and back, the trans still shifted and operated fine to my knowledge. I'm thinking the shifter linkage needs to be adjusted.
As for the cranking, I am thinking it is due to a bad flexplate, but could a bad flexplate keep a car from starting? I haven't gotten under the car to check for signs of physical damage - is there anything else I can check as well?
Any help is appreciated - Thanks!
