What would cause scuffing on the piston skirts?
New calico coated rod bearings/clevite mains
New stock replacement rings
New deglaze/hone job
Crank polished
Engine was a h/c ls2 that put down 454/425 with more left in it.
Motor has roughly 2,000 miles on the rebuild. The rods/pistons were installed. Back in the same hole they came from.
Upon tear down, all the mains/rods had significant scratches around the bearing, crank looked fine.
The piston side skirts had significant gauling/scuffing on them, and it was not there before.
What could have caused bothe these issues? Motor saw 7,000 regularly.
But I did not blow out the oil galleys when I got it back from the machine shop. Possibly some **** in the oil galleys from the machining process?
I think you answered your own question...Honing dust "gotcha"...
What would you recommend to clean the bores etc out with after machine work then?
can always use a Dexron soaked rag or towel and get quite alot of honing
grit/dirt out of the crosshatching. Then you can wipe them several more
times with a dry towel and I really prefer the Total Seal quickseat powder to
smear on the cleaned bores then install the pistons dry. The powder helps to
seat the rings during assembly...good stuff. Also take a look at all the piston
skirts on the valley side....you will probably see consistently more scratches
than on the exhaust/outside skirt as too much timing/crappy gas/ and det-
onation causes the piston to rock in the bore...perhaps the primary ring gap
was not large enough for the power level/heat you were making...butted to-
gether then cracked off a small piece of piston material...tried to compress
said piston piece into .040" of quench then the piston and rod parted ways.
At high rpm the piston **** hitting the valve can bend it and the pushrod and
knock the valve locks off making you think that thats what happened first....
chicken or the egg sorta thing....really feel for ya sir !!!!
