checking pushrod length with oem rockers?
Shims may not be required, you may need to lower the stock rockers with an aftermarket cam. How are you rotating the rockers? Are the heads on or off the car?
What cam? What lifters?
I would not shim the rocker rails.. The rockers are designed to have the scrubbing pattern... I would just set zero lash and add your desired preload..
You shouldn't have bought pushrods before you measured..
Maybe TSP will exchange you?
As for pushrods, I would also go larger OD as well.
also, this is why you measure first. regardless of what they tell you, the "cookie cutter" packages don't always work for everyone. doesn't matter if your setup has been done 100 times over or not.
I'm trying to call TSP, must be nice to just open the shop an hour late...
Ordered the 7.35" rods, TSP is going to exchange for the longer rods. Thanks again guys.
