Not happy with performance..
Old Jul 15, 2013 | 10:02 AM
JakeFusion's Avatar
Super Hulk Smash
Proxes TQ are drag radials. They hook substantially better than 555Rs. They are the same compound as the NT05R and that hooks as well as the MT DRs from what I've seen and the few magazine articles that tested them back to back.
They have the soft sidewall.
The R888s are the road race tire. It's easily the best street tire for our cars. It does dry, wet, corners, and has straight line capabilities equal to most DRs on the street.
Old Jul 15, 2013 | 10:04 AM
z28241's Avatar
The OP posted same issue in drag racing section and i stated invest in heads and good dr's
Old Jul 15, 2013 | 10:05 AM
lemons12's Avatar
O wow.... Guys, I apologize.. This is what 3 hours of sleep in over a 36 hour span will do to you.
I was reading/thinking 888Rs, which are the road race, not drag radial.
I apologize.
Thanks for correcting me on that.. I didn't even read your entire post before it hit me. LOL
Old Jul 15, 2013 | 10:07 AM
Roarin_8's Avatar
Originally Posted by lemons12
No, you are thinking of the correct ones.
They are a road race tire though.
The sidewall is the main difference.
98 heads don't have to have a reverse split... Your exhaust probably doesn't flow well enough for a reverse split anyway, most don't.
Here they are on Tire rack, they have them listed as drag radials.
http://www.tirerack.com/tires/tires....odel=Proxes+TQ
Old Jul 15, 2013 | 10:09 AM
lemons12's Avatar
Check ^ post.. I need sleep. LOL
I kept thinking 888R every time I read the post. LOL
My bad guys.
Old Jul 15, 2013 | 10:10 AM
Roarin_8's Avatar
I apologize.
yeah the R888s are the roadrace ones. Get some sleep or else you will be just like this guy.....https://ls1tech.com/forums/racers-lo...-all-time.html
Old Jul 15, 2013 | 10:11 AM
Roarin_8's Avatar
My bad guys.
Yeah I saw, I had already posted and then saw that reply.
CamaroFreakls1's Avatar
Okay so I'm obviously not trapping as high as we're all thinking? Now what do I look for? Check pushrod length double check my hoses for vac leak?
Old Jul 15, 2013 | 10:12 AM
lemons12's Avatar
yeah the 888Rs are the roadrace ones. Get some sleep or else you will be just like this guy.....https://ls1tech.com/forums/racers-lo...-all-time.html
BAHAHA... That cracked me up.
I know why I'm tired: Internet connection.
Honestly... My sleep schedule is just straight F'ed right now. I got roughly 3 hours of sleep yesterday afternoon and that is about it.. Going to try to turn it around tonight. We'll see!
Old Jul 15, 2013 | 10:13 AM
Roarin_8's Avatar
The Toyo Proxy TQs are good DRs, not better than MT DRs but better than Nittos.
lemons12's Avatar
Find out why you are only 60' 2.0.. Are you spinning that terrible?
If not, it is converter or tune.
If you have to change something big and not trouble shoot, my first place would be the converter.
You can buy a brand new PTC for 475$ shipped to your door.
Old Jul 15, 2013 | 10:15 AM
  #32
Roarin_8's Avatar
You dynoed 350 to the tire, I dynoed 363 to the tire and trapped 113 in bad DA also. Run it again in cooler weather and your mph will increase. During the wait, you can save up for better heads.
Old Jul 15, 2013 | 10:17 AM
  #33
lemons12's Avatar
Don't pay attention to the #..
I made 36XRwhp and weighing 3500# and 2200ish DA was trapping 95 or so MPH... Roughly 120mph in the 1/4.
Ran 7.2-7.3s 1.50-1.52 short times with small amount of wheel spin... Bottom 11s in the 1/4.
I don't even take into consideration dyno #s with stalled autos.
  #34
z28241's Avatar
He gets a good set of heads he will need better dr's for the added power! LOL!
Old Jul 15, 2013 | 10:19 AM
  #35
Roarin_8's Avatar
You need sleep man, that was his 60' with street tires, on the DRs his 60' was 1.76.
Old Jul 15, 2013 | 10:22 AM
  #36
Roarin_8's Avatar
He also stated he bumped the rev limiter on the 2-3 shift on the second time slip, that will hurt mph as well.
Old Jul 15, 2013 | 10:26 AM
  #37
Roarin_8's Avatar
I'm going to test that out when I put Toyo DRs on my ride and I have better heads than OP.
Actually I'll test out the Nitto DRs I have now with the different heads and then the Toyos after to see the difference.
Old Jul 15, 2013 | 10:35 AM
  #38
lemons12's Avatar
Alright, **** this... LOL
I'm going to work for a couple hours and then coming home and going to bed until tomorrow morning.
That settles my bad advice giving for the day!
Old Jul 15, 2013 | 10:42 AM
  #39
Roarin_8's Avatar
Old Jul 15, 2013 | 10:47 AM
  #40
thunderstruck507's Avatar
Even in high DA I would expect at least 111mph from your car based on mods.
The top end of your dyno graph looks rough. Might be a clue.
