408 stroker 6.0L iron block, share your knowledge!
Ok found a good deal on a 6.0l iron block that has just been bored out for a 408 stroker. Just want to make sure everything from my 99 ls1 will interchange as far as accessories and the harness and sensors.
Casting number on the block is 12577184 is it a lq4 or lq9?
The casting number on the front of the pass head is D065
manufactured April 6th, 2005 according to that i believe.
So it comes with a k1 4in crank too so it should be 24x to work with my 99 harness?
Anything i should know about the swap?
Thanks
Thanks
12577184
98 & UP
365
Gen III 6.0L Iron Block. LQ-4 and LQ-9
This is all I could find so it seems the block is the same. To my knowledge they used the same block but the heads and pistons made the difference in power/compression.
This link might help you during your build.
http://outintheshop.com/faq/casting/castings2.html
98 & UP
365
Looks like the knock sensors are in the same spot in the valley. Also, I have the truck 145 amp alternator, does that change anything? Thanks for the info guys. Any clearancing I should be aware of before I start the build?
Everything should bolt up fine, have to drill a hole for the alternator. Everything on the back will bolt up the same. Internally your gonna have to clearance the windage( i just used a bunch of nuts) and you may have to clearance the oil pan (i did). I would also check the pickup tube and make sure its not too close to the bottom of the pan. Here's a link to my build thread if you want to read what i did: https://ls1tech.com/forums/generatio...-pressure.html
