Summit Racing 6.0 LS Block
The cylinder measured within 2/100 mm within the piston mfg. specs, from top to bottom measured also 90 deg. to the thrust axis.
That is more then adequate if you using out of the box forged pistons for a mild turbo setup - what i did.
Main bearing bores were line honed (also nicely within factory specs.), decks machined, threads cleaned, cam bearing installed.
All the block needed was a good cleanup prior to assembly.
personally i would not expect more for the amount paid.
So basically once you put a plate on it it needs to be a .40 over block.
I still have it sitting there bc i couldnt use it... Waste of money for me.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Now that's a response that will make me spend a lot more money with Summit....
got many parts to buy.
Thanks Oscar.
I highly recommend them.
THESE MEASUREMENTS ARE WAY OFF....GETTING 4.0295 + OR - .0005 OOPS
