Summit Racing 6.0 LS Block
he offers a 5% discount for LS1tech members. My block is coming in this morning so I'll post pics later to compare.
My bare block from ATK Performance (User "Notalent") arrived today.
I must say I was very pleased with the total transaction as a whole. I called Brandon at ATK on Wed. last week (1/15/14) and ordered a Lq4 bare block. It arrived today via freight delivery.
Block arrived well packaged. I had already opened it up to verify contents before taking this pic.
Again, very well packaged.
Block itself looks great. Bores are clean and block itself appears in great shape. Gave it a good solid look over. New cam bearings and oil galley plugs check.
Again, well packaged, well shipped, and the block looks to be in great shape. I don't have a bore dial to check the .30 over bore yet though. But I have no doubt it was done correctly. Again, very well done for ATK. Now to start building my 408.
I rec'd the block and dropped it off at machine shop to have it drilled & tapped for 1/2" head studs and 11mm main studs also. $450 of work later I get it back to discover the thrust bearing had been worn through and the crank cut into the block and main cap rendering the block useless. Summit will not cover the $$ I am out for the machine work just refund the block $$. Also the main caps were run across a belt sander instead of being ground, and the caps were scratched & beat up on the ID from the hold-down bar, the main hone should have been the last process done.
Stay away from these blocks is all I can say!!
Summit won't be getting another dollar from me ever after this!
That being said, on a side note, the main hone is always the first process done in machining. All other measurements are based off the crank centerline
With a thorough checkout, this block sounds like a good way to go for people building their own motors on a tight budget.
The bottom line is I am not paid by Summit to perform their quality control, nor should I have to pay someone else to do it for me, that is why I bought a finished product from a supposedly reputable vendor.
http://www.summitracing.com/parts/SUM-150105/
First off, I'd like to say Thank You to Oscar and Summit Racing for the OUTSTANDING customer service. I've always purchased my stuff from the local store here in Reno. Never had an issue that wasn't easily resolved. I will always do business with Summit Racing.
I bought this block about a year ago and didn't get to work on it until about 2 months ago. I put the Bore Dial Gauge to the Cylinders and found that NONE of them came in at 4.030". They all ranged from 4.0260" - 4.0280". None of them were consistent at all. With the engine still sitting on the crate, the cylinders were out of round. They were completely warped, and had inconsistencies between the top and bottom of each bore.
They're also advertised as having NEW Cam bearings installed. Not mine. Not even close. (However, the one recently aired on Power Nation DID have New Cam Bearings) go figure...
I also purchased a set of Wiseco pistons for a 4.030" bore prior to checking this block. And although Summit offered to buy back or swap out the block, I decided to take it to my local machine shop to get the cylinders honed to the correct size, check the line hone and install NEW Cam Bearings. I'll be picking it up this afternoon.
Anyways,
I just wanted to post my experience with this block. Hopefully the shortblock assemblies coming out of ATK aren't built on these foundations/specs.
needs new holes drilled?
