Will LS7 lifters hold up?
Old Aug 3, 2013 | 12:01 AM
mobman's Avatar
Default Will LS7 lifters hold up?
Will LS7 lifters hold up on a .630 lift cam or is there a better option?
Old Aug 3, 2013 | 12:27 AM
PREDATOR-Z's Avatar
morell
Old Aug 3, 2013 | 02:54 AM
zzcamaro00's Avatar
Originally Posted by PREDATOR-Z
morell
i second this.
Old Aug 3, 2013 | 06:41 AM
vettenuts's Avatar
Morel were designed to prevent oiling problems with higher lift. Many other better qualities about them as well.
Third for Morel.
Old Aug 3, 2013 | 07:43 AM
therabidweasel's Avatar
Down at the bottom of the link below you can find a post that is just scratching the surface of why some pretty big named builders are quietly shifting to Johnsons. Some have picked up > 50hp and 500 more RPM until float on a lifter change (from Morels), not that Im knocking them. Im just aware of some of the latest results. Morel are obviously fine and proven.
https://ls1tech.com/forums/showthrea...621905&page=22
Old Aug 3, 2013 | 07:52 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'll be one of the guys going to Johnson's here in the near future as well.
Having said that, I've got .631 on both intake and exhaust and my car runs like a champ with the LS7's. No issues.
Old Aug 3, 2013 | 08:47 AM
96lt4c4's Avatar
My LS7's were ticking pretty good only at hot idle, installed Brian Tooley Racing SLR lifters and idle tick is gone.
Old Aug 3, 2013 | 08:54 AM
td1168's Avatar
Not to hijack the thread but I'm running the ls7 lifters with my ms4 and I do have valvetrain noise at low rpm's when the car is hot. I've been running the ls7's for 7k miles now without issue. I'm not real concerned with the valvetrain noise. I've heard the noise with the ms4 is normal.
Old Aug 3, 2013 | 09:14 AM
Decadence75's Avatar
What about the BTR SLR lifters? I've read good things about them and was planning on putting those in the next time I had the heads off.
Old Aug 3, 2013 | 09:47 AM
squirlNUTZ's Avatar
I don't think you can go wrong with Brian Tooley any thing.
Old Aug 3, 2013 | 09:50 AM
dr_whigham's Avatar
The Scammer Hammer
Originally Posted by squirlNUTZ
I don't think you can go wrong with Brian Tooley anything.
Quoted for truth.
Old Aug 3, 2013 | 10:37 AM
ckpitt55's Avatar
There was nothing in this thread that led me to believe that the slr's were any better than running ls7s. Brian kind of even says it towards the end of the thread.
https://ls1tech.com/forums/generation-iii-internal-engine/1629882-anyone-running-brian-tooley-slr-lifters.html
Their internals with those are much better toleranced than the ls7s which is why you get more net valve lift, but they're also more prone to valve float if you're to the point you're lofting the valve train - slow leak rate = takes longer to bleed down. I've also heard of Brian actually recommending ls7s over the BTR's.
If you're after a good lifter, get some morels or Johnson's. spintron data confirms them to be 2 of the best options available on the market.
Old Aug 3, 2013 | 04:41 PM
mobman's Avatar
I wouldn't be reving mine above 6500. I don't race it so maybe the LS7's are the way to go. I would hate to spend allot extra for the morels if the LS7 lifters would a reliable option.
Old Aug 3, 2013 | 07:35 PM
BrntWS6's Avatar
I spin mine to 6800 rpm on a .643 lift cam and no issues with the LS7s after two years.
Old Aug 3, 2013 | 07:44 PM
KingPin1094's Avatar
I have lunati street lifters (relabled morels) and i have .629/.629
Old Aug 3, 2013 | 11:56 PM
red fury's Avatar
I ran the LS7s for a few years (about 36k miles) with .646/.612 lift and spun it to 6900rpm n/a and spray with no problems. Don't forget, the c6 zo6 boys spin much higher rpms after they do cam installs.... 7200 ect
Old Aug 4, 2013 | 01:47 AM
JakeFusion's Avatar
Super Hulk Smash
Johnson Short-Travel. Will handle anything you can throw at it.
Old Aug 4, 2013 | 10:29 AM
chrs1313's Avatar
Wow I didn't know they use Johnson short travel lifters in Top Fuel
That is a pretty big sweeping statement, I would just state your personal experience, because just a few weeks ago you had morels and thought those were the cats meow...
I know of 4 people personally that have had ls7 lifters fail and take out a cam...and I also know of lots more making the same power and their ls7s are fine...keep the ramp rates soft and valves light, a good spring with not huge open rates is a good idea too...
I have morels and they have worked so far for me nicely...Johnson's seem to be a decent lifter too but I have no first hand experience, and if you do go with the ls7s make sure you check the rollers out and they roll freely and smoothly out of the box...I have felt a few brand new ls7s that were gritty when rolled...I am not sure if their quality control has improved in the last year but it seemed to be less that up to par before
Old Aug 5, 2013 | 08:06 AM
96lt4c4's Avatar
https://ls1tech.com/forums/showthread.php?t=1629882
I had the same discussion with Brian. I tried a few things to see if I could get the LS7's to stop ticking at idle, moved preload all around, nothing worked. I made the decision to pull the heads and swap the lifters out to the SLR's. I took an LS7 and a SLR apart to compare and the from what I can tell the SLR is a better lifter. The SLR plunger is bigger diameter than the LS7, allows more oil in the lifter, the SLR has a spring loaded check disc in the bottom of the plunger, the LS7 has a non spring loaded check ball, the SLR plunger has a closer tolerance to the body of the lifter, where the LS7 is mass produced and the plunger to lifter body tolerance may vary, causing some to tick louder than others. If you run the SLR's you want to keep the preload small. I am running a short 7.325 push rod which was giving me around .045 preload.
Now valve train is quieter. I spin the motor to 7000 RPM rev limit 1st-2nd blowing the tires off. The thing revs like a 2 stroke. I am very happy with the SLR lifter.
Like you said as long as the rest of your valve train is in check there should be no problems with either lifter, but the SLR is better in my opinion.
I am running an XFI intake lobe and a XER exhaust, Brains springs and titanium retainers, and Ferrea solid valves that TEA put in my heads. Stage 2 LS6 port work.
Old Aug 5, 2013 | 08:18 AM
Rise of the Phoenix's Avatar
Stock lifter here and I'm turning my beast over to 6500 rpms. No issues at all. Just make sure you have everything setup correctly.
