Valves hitting Pistons W/ T-ReX!!! Need help (probably my fault)
T-ReX is in. Heads are on and torqued (stock unmodified heads). rockers are on and torqued. Put on a new oil pump, stock timing chain and gears, lifters. I bought TR's cam package with cam with 7.4" pushrods. Using Victor Reinz headgaskets. I didn't use a degree wheel. I did however line up the dots, and they line up perfectly (I think).
Any ideas why they're hitting? I'm pretty sure it's the valves hitting, as I can't really look in there to tell. It sounds like it's coming from around that general area. I can turn the cam gear, probably, 1/3 of the way around, before it hits something and stops.
cam specs are 243.8/249.7 .609/.615 109.9. I'm no cam expert, but could that extra bit of duration and lift, cause the problem?
I asked my local board, COFBA, and they've thrown out a few ideas (BTW, thanks guys), but, I figured i'd put it on this board too.
Called TR and the guy said it might not be degreed properly. I have no idea how to use a degreeing wheel, but I thought all I had to do was line up the 2 dots?
Advise?
Advise?
...when I spoke to Texas Speed, they told me I would have to degree the cam and notch the pistons for that cam...look at the lift .609/614...did you clay it prior to installing just to see if it was going to touch or not? How deep is the indention on the piston? Did they advice you to go with a shorter push rod?
Originally Posted by Damian
Aside from having PV problems, have you tried to force the motor over the first time you felt contact? If so you've bent that valve and however many others if you forced it to turn over...Just a FYI..
I rocked the car kind of hard while in gear, and it wouldn't roll. I didn't think anything of it. I then turned the crank witha wrench, and got to a point where it wouldn't move and put a fair amount of pressure on it. I did not, however, force it past that hard point. looks like I'm taking the heads off again.
Can I reuse the new headbolts and headgaskets I just put on there?
They were torque to yield GM bolts. That saves me another $50 if I can reuse those, thank God. I might go ahead and order the thickest headgasket I can find, while I've got it apart, again.
I can shift faster than you.
Sorry to hear about your problems. First thing I would do would be to remove the rockers and try turning the motor over. See if this allows the motor to turn over freely.
The cam specs are perfectly fine. Most of the TReX cams do check out slightly larger than the advertised 242/248. The specs on the cam in my car are 243.6/249.0 109.8*lsa/108 intake centerline and this is the one we based the .070"/.090" piston to valve clearance on with bone stock LS1 heads, stock shortblock/rockers/gasket (.053" compressed graphite gasket),etc. Peak valve lift has ZERO effect on piston to valve clearance.
What were the heads removed for?
Good luck and feel free to give me a call at the shop if you have other questions/concerns.
Jason
Jason
Were they torque to yield gm bolts or ARP...many people reuse torque to yield bolts without any problems.
You are setting yourself up for failure. This is a well known fact. TTY are meant to be stretched to their final torque spec. Once you break them loose they do NOT recoil and can thus not be re-stretched to their final torque spec. Therefore you'll never have the heads torque completely and you'll risk blowing your headgaskets, etc.
The cam specs are perfectly fine. Most of the TReX cams do check out slightly larger than the advertised 242/248. The cam in my car are 243.6/249.0 109.8*lsa/108 intake centerline and this is the one we based the .070"/.090" piston to valve clearance on with bone stock LS1 heads, stock shortblock/rockers/gasket (.053" compressed graphite gasket),etc. Peak valve lift has ZERO effect on piston to valve clearance.
Jason
Jason
I pulled off the drivers side head, and the valves are definitly hitting the pistons. Infact, I broke the exhaust valve on # 5 cylinder. I have no idea why. I didn't degree it, but those dots were lined up perfect. damn damn damn.
Originally Posted by CANNIBAL
THIS IS ABSOLUTELY INCORRECT. YOU CAN NOT RE-USE TTY BOLTS OF ANY KIND.
I agree with you and would not use them either so no need to scream... I was simply telling him what others have done and done without any problems from what I was told.
LS1TECH Sponsor
reusued mine in my s-10 and blew the gasket in about a month lol so yah dont reuse TTY bolts. Sux to hear you fucked up the heads too now...one way or the other those funds will have to make themselves available lol once you start going that big with a cam you really should check and double check everything...these cams are pretty much race only and should be treated as such.
lata
Bill
lata
Bill
I have ASE certification manuals, books, etc that re-iterate this time and time again.
Sure, it may be somewhat OK to re-use ONE to get you back home, shut it down and order a new one from the dealer but never a full set.
It's incorrect information that you heard and it can cause some people grave consequences if they heed that advice. If you notice, the person was relieved that they thought they could re-use the TTY bolts they had just used (torqued to final spec) and it saved them $50. That $50 saved could cost him a TON more if he/she were to re-use them and they failed b/c they heeded that advice.
See the quote here:
A local (fairly reputable) shop asked me why I wanted new head bolts. I told him they were TTY and he said the shop re-uses them. I still bought a set for piece of mind.
The dealership's name is Lou Fusz Pontiac in St. Louis, MO.
I didn't **** up the head or the pistons that much. It put a knick in the combustion chamber of #5 and also took a small gouge out of the piston. I've got a set of 5.3l heads sitting here also. Can I just swap the valves?
Also, I checked time and time again, and those dots are spot on. I can't figure out for the life of me why they're hitting. I'm gonna go ahead and fly cut the pistons and throw on some cometic gaskets, and new head bolts. That was a hell of a fuckup.
But it still bothers me why they hit.
