Should I run 7.350 Pushrods?
5.7L LS1 Heads milled .022 w/ 2.02/1.60 SS Valves..
Right now I'm running 7.4"... My valvetrain is really noisy.. (sewing machine) would the shorter rods quiet this down any?
mike
This calculator will give you the pushrod length by a calculation based on your heads being milled and cam base circle, etc.
Here ya' go: http://home.insightbb.com/~l.proctor1/p-rod.xls
Enjoy!
This assumes stock spring installed height for an LS1. The stock pushrod size is base on an LS1 stock pushrod.
However, the only real way to tell is to check your preload, etc.
mike
Thanks.. I'll go with a set of the Hardened 7.4" Rod from Thunder...
