Rectangular Ported 241's!!!
Old Aug 16, 2013 | 09:56 PM
McCain_Racing's Avatar
Exclamation Rectangular Ported 241's!!!
What's going on Tech! I have recently purchased a forged ls1(stock cub) and went to freshen up the motor just for safety and come to find out the thing has a "unique set of unheard of rectangular ported 241's"
Take a look at these photos, maybe you guys can see if any of your engine builders can try this if you're on a budget build!!
Intake Port Dimensions:
1.217 x 3.284
Old Aug 16, 2013 | 11:20 PM
A.R. Shale Targa's Avatar
,someone obviously spent some time going old school mentality
on those and they probably flow well at .550-.700 lift but I'd bet the low/mid
lift numbers are quite lazy and non efficient. They would be OK for a turbo
application or maybe a nitrous drag only setup.
Old Aug 16, 2013 | 11:41 PM
01cherryreds10's Avatar
I think you should run these and then come back and let us know what happens lol
Old Aug 16, 2013 | 11:51 PM
LilJayV10's Avatar
Have them flowed. I'd be interested to see what they do. Bigger is not always better.
Old Aug 17, 2013 | 12:25 AM
CattleAc's Avatar
I'll almost bet money an old "Big Block Chevy" guy did those...
Old Aug 17, 2013 | 12:35 AM
LilJayV10's Avatar
What does the port work look like behind the valve?
Old Aug 17, 2013 | 06:43 AM
They are ported to the bone in the intake and exhaust ports. My 3700 camaro with an 4l80e and 3600 stalled and 175 shot got me to 6.50's with those heads..?!
Here's a video of the pass:
Old Aug 17, 2013 | 06:57 AM
KCS's Avatar
KCS
Moderator
Not sure if that was a good idea. More pics please.
Old Aug 17, 2013 | 07:22 AM
wildcamaro's Avatar
Holy Haggan Dazs port job...someone had some quality time with a carbide bit lol...they aren't even straight lol...but I would still like to see a flow bench on them before I count them out, you never know could be the next "thing", people running ls3 intakes on modified cathedral heads...
Old Aug 17, 2013 | 08:33 AM
xRaTeD's Avatar
Lets see inside the port..
Old Aug 17, 2013 | 09:34 AM
redtan's Avatar
Yeah I agree.
Looks nice and big on the outside, but how does the inside look like? I'd bet not even close to what a true rectangular port is which means it's just the opening like that.
Old Aug 17, 2013 | 10:05 AM
wildcamaro's Avatar
Yea drastic transitions are not good for flow charecteristics...although on the video that car ran pretty damn good...definitely intriguing....OP what else is done to the car?
Old Aug 17, 2013 | 11:45 AM
The Car is a pretty basic setup, it's has bmr everything under the bottom with 12 bolt and spool, the motor is just a stock block ls1 with pistons, rods, bolts and a 59x cam with a little 175 shot on her. It would probably pick up if i slapped a victor jr and 4 barrel throttle body on her because the stock ls1 intake length matches the heads but the width is only .997 and if you were to try to port it any further than that you'll be interfering with the gasket slot.
Here's a picture of the inside of the port, looks to me as whoever did these heads put some labor into them.
Old Aug 17, 2013 | 01:16 PM
badazz81z28's Avatar
One thing that you forgot that old school BBC guys did...was WELD UP the runners!! When you hog the ports out like that, how thick do you think the runners are now? Probably paper thin. Unless the porter re-enforced the runners somehow, I wouldn't run them.
Old Aug 17, 2013 | 07:20 PM
LS1MCSS's Avatar
Why not? They came off of a running engine.
Old Aug 17, 2013 | 07:40 PM
That doesn't make them reliable.
Old Aug 17, 2013 | 08:19 PM
TT427's Avatar
Possible a dry style intake can crutch a sinkhole of an intake port?
Old Aug 18, 2013 | 10:30 AM
As the other guy said..they came off of a running motor and a damn good one at 3700 pounds. So the not running them is out the door, I have plenty of knowledge about these ls motor, sbc's, sbf's, bbf's, and bbc's, I wasn't brought into the racing game yesterday. Me and my brother owned one the fastest stock bottom end ls1's on the planet till this day and plan on bringin another beast back out!
Best e.t. with our mustang @ 3260 race weight:
60ft- 1.25
1/8th- 5.80 @ 118
1/4- 9.50 letting out of it
This is the 5.80 pass
Old Aug 18, 2013 | 11:49 AM
03Sssnake's Avatar
Love the notch!!
Old Aug 18, 2013 | 04:49 PM
Justhereforinfo's Avatar
The material inside the intake ports doesn't look like aluminum. It looks like someone over ported the intake ports, then filled them with some kind of casting, then ported them again.
